Temperature Display on Heator Wrong
Old Jan 12, 2018 | 04:12 PM
Larry-Cleveland's Avatar
Default Temperature Display on Heator Wrong
Hi Guys,
The temp that is displayed on the heater display, (non-nav) has gone nutz. Switching back and forth from F to C to F did not help. The other day when it was -2F out it showed 107F. What a swing! Always wrong by different amounts.
I know on some cars the temp shown is used by the computer to adjust the mixture. Is this true on our Jags? The is running fine.
Any idea on the sensor location and how to fix.
Thanks!!!
Old Jan 12, 2018 | 05:17 PM
avern1's Avatar
I am assuming you are pressing the external temp button. Yes it does make a difference in my XJ8 I could only get heat with the heat set to HIGH. The external temp said it was a 137 degrees outside and wanted to run the air conditioner in 30 degree weather.
Below is a view of where to find the sensor. I don't remember when I changed the one in my X-Type if I was able to reach thru the bumper or had to take the splash guard off. Thru the bumper I think.
Attached Thumbnails Temperature Display on Heator Wrong-ambient-temp-sensor.jpg
Old Jan 12, 2018 | 06:33 PM
ooppss I am talking about the outside temp that is displayed in the top right corner.
Sorry
Old Jan 12, 2018 | 06:36 PM
Oh I see it now. I will swap it off my other car to see what it does.
Old Jan 12, 2018 | 09:07 PM
Thermo's Avatar
Veteran: Navy
Larry, if your temp is bouncing all over the place, yet is a fairly accurate reading (ie, not pegged high or low), then odds are your problem is the sensor itself. If you have a wiring issue, it will tend to bounce to the max indications.
monz87
Sep 21, 2016 08:07 AM
innzane
Jan 23, 2015 08:31 PM
lozzer65
Apr 15, 2014 05:59 PM
Geordie1
May 6, 2012 03:35 PM
timxtype02
Mar 18, 2008 09:19 PM
