throttle body leak
Old Oct 17, 2010 | 09:04 PM
satwarez's Avatar
Default throttle body leak
Hey guys can u tell me if a leak in the throttle body O rings can cause the " cruise not available/gearbox fault" warning lights. much appreciated
Old Oct 18, 2010 | 11:08 AM
sidewalkman's Avatar
Do a search for Cruis not available, there are a number of factors, all of them related to vacuum leaks.
Old Oct 18, 2010 | 12:56 PM
Mayor111's Avatar
I had the same problem only a week ago and its now been resolved. Read the thread I started to help you get the ball rolling:
https://www.jaguarforums.com/forum/s...ad.php?t=43616
Old Oct 18, 2010 | 07:30 PM
I <3 X-Type's Avatar
Usually if it has a gearbox fault light it leans more towards the throttle body as ive heard thats the culprit most of the time. God i hope it isnt it cuz it NOT CHEAP!! If you are experiencing symptoms of limp mode sometimes with your check engine light and cruise not available then,"goes away" Then "comes back" its usually vacuum leak. And id check into the IMT O-rings like MAYOR said. Check his post and you will find the exact location of the o-rings as he posted a pic (second page). Thats like 8 bucks from the local Jag dealer.
Old Nov 3, 2010 | 08:05 AM
queensnewbie's Avatar
Well this is the second cold season in a row I have had the "cruise not available." although this time there is no check engine light showing like there was with the first time. I changed an o-ring last year. The cruise not available seems to show randomnly, not everyday and no limp mode-- the car runs like it always does. Should I be looking at vaccuum leaks again?
Old Nov 3, 2010 | 08:17 AM
Brutal's Avatar
Please read xtype faq's these issues have been brought up so much that theres a wealth of info. Even to the point that non mechanical members are giving the answers. Yes vacuum leaks are the normal cause, and theres alot more than imt orings that cause vacuum leaks, brake booster pipe check valve, intake gaskets, pcv hose, imt's and an occassional brake booster diaphram leaking
Old Nov 3, 2010 | 08:27 AM
Great, thanks. I realize it could be something other than the IMT rings, I thought I would ask since the CEL is not showing like last time. I will look into the FAQ's. thanks again.
Old Nov 3, 2010 | 05:32 PM
Jagtec1's Avatar
Definitely fix it, or it'll need cat(s) too!
Old Nov 3, 2010 | 10:52 PM
sorry for coming across as ignorant but what are "cat(s)"? Catalytic converters? thanks
Old Nov 4, 2010 | 07:53 AM
Brutal's Avatar
No theyre small furry animals that lay around all day lick themselves, dont fetch, dont jump up and greet you when you come home, theyre temperamental, if the litter box has new litter in it they just go next to the box just to **** you off, uhm where was i? Oh yeah on a car theyre catalytic convertors
Old Nov 4, 2010 | 10:43 AM
lol, as you can tell i'm not a car guy. Thanks for the clarification!
clubairth1
30
Sep 3, 2025 04:38 PM
silkcat
Jan 18, 2025 04:29 AM
xjrjag
Oct 24, 2024 03:09 PM
Gus
Oct 15, 2019 12:29 PM
