Ticking noise in engine
Old Apr 3, 2019 | 10:48 AM
jgpflaumer's Avatar
Default Ticking noise in engine
My 2006 X Type 2.2d Estate has developed a "ticking" noise in the engine. It sounds like a valve lifter or possibly an injector, but I have been all over the thing with a stethoscope and can't find an obvious source. Any thoughts?
Old Apr 3, 2019 | 01:38 PM
Dell Gailey's Avatar
Timing chain guides
Old Apr 3, 2019 | 09:16 PM
car5car's Avatar
I usually use 2 types of stethoscope:
mechanics (with a stick)
"medical" (no stick). I stole toy stethoscope from my daughter, it works fine.
Another way to locate sound is to use camera. Move camera around engine and, when you watch video on computer you'll hear where the sound come from. Post video on youtube and link here.
Old Apr 4, 2019 | 03:54 AM
jgpflaumer's Avatar
Originally Posted by Dell Gailey
Timing chain guides
Thank you for this suggestion, but I suspect it's something else. The ticking is regular and at half engine speed which suggests a possible faulty valve lifter. My stethoscope is the mechanics' type with a probe and I've been all over the engine and ancillaries without being able to locate the source.
Old Apr 4, 2019 | 08:30 AM
car5car's Avatar
Lifter noise is usually easy to locate, including cylinder, there should be big difference between heads.
Crank knock is harder, did you check oil pan?
mit2700
Jun 8, 2016 10:38 AM
91stealthes
Nov 8, 2013 03:49 AM
Sixx Dogg
Jan 29, 2013 06:20 PM
mrdobsie
Apr 14, 2011 02:00 PM
sinatrakat
Sep 24, 2010 06:38 AM
