Tire pressures
Old Oct 18, 2006 | 01:32 PM
Humy's Avatar
Default RE: Tire pressures
depnding on what size you have, it is different
check the inside of your gas cap panel
Old Oct 18, 2006 | 07:14 PM
racerx82's Avatar
The best palce to check for the true actual tire pressure is on the tire itself. Since tires come and go and most people never replace woth the same factory tire, the sticker (located on drivers side door piller) can be misleading.
factory tire pressure for my 05 calls for 38 psi front, and 35 rear. i found that if i run 32 front and rear i get a better ride....
________
Nevada Marijuana Dispensary
Old Oct 19, 2006 | 04:43 PM
Humy's Avatar
I run Kumho Ecsta ASX all-seasons at 32 psi all the way around as well
Old May 11, 2008 | 07:48 PM
CougarBlack's Avatar
Does anyone use 30PSI on their sport wheels(17in aguillas) The cap says 0-100=30Psi and it jumps to 38 above 100mph
Old May 11, 2008 | 08:13 PM
Dennis's Avatar
ud
ORIGINAL: Humy
I have the same tire (love them)..and I run 37 PSI on all 4..Ride is a bit stiffer, but they wear better
Old May 11, 2008 | 08:26 PM
Oldengineer's Avatar
My X has 17 inchers and I run 38 in the fronts and 35 in the rears.
Regards:
Oldengineer
Old May 12, 2008 | 08:12 PM
Chas944's Avatar
ORIGINAL: CougarBlack
I have those same wheels with 225/45-17 Continentals and I run 38psi up front and 36 for the rears. I have always noticed that the fronts really squat more with less psi.
Old May 12, 2008 | 08:49 PM
Im glad ya'll said that because 30 just seemed unreasonable. and it also seemed like it help destroy the walls of the tires. just got new goodyears i wanna to see how they hold up cause i never went for that brand before. i saw carbin fibre walls and went for it cause all 4 of the contis had bubbles in them. Ive never had that happen before. worst part is that i had a lot of tread left, so it was like i was throwing away prematurely
Old May 12, 2008 | 09:54 PM
Dennis's Avatar
ud
If any tire is run for very long on low pressure, the side walls will begin to blister because the plys are starting to leak through the layers and traps air in the outer skin...Good thing you replaced them..they were a blow out waiting to happen
silkcat
Jan 18, 2025 04:29 AM
amaezing
Sep 18, 2015 03:25 PM
johndahlheimer
Sep 16, 2015 05:44 PM
Armor6
Sep 14, 2015 07:56 PM
Armor6
Sep 10, 2015 12:08 PM
