Transfer Case Oil Change
Old Apr 12, 2008 | 10:01 PM
survey_sez's Avatar
Default Transfer Case Oil Change
when changing my tranfer case oil, i discoveredthat refilling with 600 ml is a bit to much. what has happened is that the right side seal *appaered* to be leaking after the change. in a way, i began to worry, because i had not measured the amnount that drained - and the thought that the seal was defective had crossed my mind as something that could be real. however, i took the car in to have the seal inspected further, and my mechanic said that the vent was in the vicinity above the right side seal, and that he believes this is where the oil was coming from. so, something to be aware of...
Old Apr 13, 2008 | 08:03 AM
survey_sez's Avatar
Default RE: Transfer Case Oil Change
when filling - it's nice to think you're compensating for the amount of oil you will loose that stays in the fill hose, and the amount you will loose when playing switcheroo with your thumb while replacing the drainplug. that's hard to predict and will be based on the diameter of the fill tubing used, and how many beers you've had...in my case, 600ml was compensating to much.
i thought it would help others toexplain that slight overfill can possibly be misinterpreted as a leaky right seal...and other than that,i don't think there is any danger in overfilling whatsoever. i began noticing oil on the garage floor.
my tool by the way requires no soldering and virtually no assembly. i'd like to post pic of it, but i get an eroor 'file to big'.
Old Apr 13, 2008 | 09:35 AM
jag_genius's Avatar
well that drain plug isnt really a drain plug.. so when you think you have it all out you dont.. there is still maybe 50-80 ml still in the transfercase..the realdrain is when you remove the flange.. but thats to much work.. subtracting it and measuring it wud of been good.. any more just gets pushed out when heated up..
Old Apr 13, 2008 | 10:36 AM
jagxtype's Avatar
would a hand pump with a hose connected to a barbed NPT fitting work when doing this?
Old Apr 13, 2008 | 10:49 AM
survey_sez's Avatar
that would work just fine. i chose a barbed fitting also - and afunnel bunged onto the hood in the engine compartment.
Old Apr 13, 2008 | 10:56 AM
jagxtype's Avatar
Cool...thanks for the input. I appreciate it!
Old Apr 13, 2008 | 11:11 AM
survey_sez's Avatar
i think you'll still want a shutoff valve tho - so you can detach and set down the pump after filling without allowing the case to drain back. then you'll be able to unscrew the fitting with one hand and quickly put the plug back in with the other hand without a third hand to fumble with the pump...
Old Apr 13, 2008 | 12:30 PM
jagxtype's Avatar
sounds good to me.
Old Apr 13, 2008 | 12:37 PM
survey_sez's Avatar
here's the pic of my tool. all parts except funnel can be found at lowe's. funnel is from walmart.
[IMG]local://upfiles/3676/1C7B95CF452C443090E45828A2294094.jpg[/IMG]
Old Apr 14, 2008 | 05:48 PM
ancientsanskrit's Avatar
Very nice Survey; picture will come out in hand this summer. Thanks.
Old Apr 14, 2008 | 09:12 PM
hankycbr's Avatar
what oil did you use for this job?
thanks!
Old Apr 15, 2008 | 05:14 PM
survey_sez's Avatar
valvoline synthetic 75W140
bamforp
Aug 14, 2024 05:36 PM
Jpav27
US Northeast
Dec 17, 2021 05:40 AM
ZJag
26
Sep 5, 2016 03:33 PM
afterburner1
Dec 16, 2015 12:12 AM
pnwrs2000
Sep 3, 2015 11:55 AM
