Transmission help!!!
Old Mar 12, 2008 | 03:06 PM
Dennis's Avatar
ud
Default RE: Transmission help!!!
That's the problem with flushing a tranny with a lot of miles on the original fluid..It cleans too much all at once and the crud breaks loose and clogs hydralic channels and valves within..This is especially true if you go many miles on a tranny before you flush it..that's why it's always best to drain and refill every so often to keep the transmission fluid clean and free of sludge.
IMO!
Old Mar 12, 2008 | 03:27 PM
ruslan35's Avatar
Hey Dennis, this kinda of reportsmake me what to forget about doing anything with trany fluid. Even drain and refill doesnt sound too much fun anymore.
[sm=forgetit.gif]
Old Mar 12, 2008 | 03:31 PM
FactoryJaguarTech's Avatar
Those codes indicate transmission replacement is in the works.
You might be able to find a shop to rebuild it. It is a Jatco box.
Old Mar 12, 2008 | 03:57 PM
Make sure the fluid level iscorrect first. Also clear the codes after setting fluid level correctly. An outside shop may have put incorrect fluid in there also when they did the flush. Fluid is expensive.
Old Mar 12, 2008 | 04:43 PM
jvegas's Avatar
what kind of fluid was put into it when they did the work?
Old Mar 12, 2008 | 07:51 PM
ruslan35's Avatar
FJT, while we are on this topic, do you have any suggestions about a fluid? (other than factory)
Greatly appriciate it.
Old Mar 12, 2008 | 08:27 PM
People seem to like Amsoil. There is a post here on fluid changes. Lists all the oils used and amounts. Personally with the trans I would use only jatco fluid. Itstheir trans and they are sensitive.
Old Mar 12, 2008 | 08:42 PM
ruslan35's Avatar
Yeah.. goodluck to us mortal users to finding that jatco fluid in US.
Old Mar 12, 2008 | 09:58 PM
ruslan35's Avatar
Here is an interesting article i found:
THESE ARE THE VIN AND SERIAL # SPECIFICATION ON CAMPAIGN XT307-S941 A/T REPLACEMENT. THE PROBLEM IS THAT YOUR VIN NUMBER WILL NOT SHOW UP IN THE OPEN CAMPAIGN LIST BECAUSE THEY DID NOT SPECIFY SPECIFIC VIN NUMBER IN THE CAMPAIGN NOTIFICATION... BUT AS YOU CAN SEE BELOW IT IS ANY CAR WITH A VIN NUMBER IN THE RANGE FROM C00519 TO C62327 WHICH IS 61808 VEHICLES!!!CAN ANYONE SAY CLASS ACTION. IF YOU CALL YOUR LOCAL JAGUAR DEALER THEY WILL TELL YOU THAT THERE ARE NO OPEN CAMPAIGNS ON YOUR VEHICLE... DO NOT STOP THERE TAKE THEM THIS DOCUMENT AND STICK IT UNDER THEIR NOSE...!!!
Action:
The repair of vehicles within this service action must be targeted in a specific order.
Note the following when scheduling vehicles to replace their transmissions:
1. Unsold vehicles and vehicles that have less than 3000 miles on them MUST have a NEW transmission installed, not a remanufactured transmission. These vehicles take priority over all others as new transmissions have been supplied to start the service action. (A remanufactured transmission can be identified by an affixed label stating "remanufactured" adhered to the top of the transmission).
Note: Only transmissions with an EKA suffix can be used in this Service Action. Transmissions with an EKA suffix must not be used to repair any vehicle not specifically covered by this service action.
2. Transmissions manufactured in September and October 2001 are more susceptible to this concern and therefore the customer contact strategy should focus on those vehicles within the VIN range C32605 to C62327.
3. Vehicles within the VIN range of C00519 to C32604 should be contacted last.
Note: Some vehicles contained in this service action may already have a replacement transmission. If so, the vehicle might not be eligible to receive a replacement transmission.
To determine whether the transmission requires replacement, check the transmission serial number. Replace the transmission only if the serial number meets the following conditions:
^ 2.5L and 3.0L starting with 11xxxxx.
^ 2.5L and 3.0L starting with 12xxxxx.
^ 2.5/3.0L: 1300001 - 1399999.
^ 2.5L: 1908190 - 1999999 & 1X00001 - 1X08740.
^ 3.0L: 1908384 - 1999999 & 1X00001 - 1X09438.
Note: If the serial number has a letter stamped behind it, do not replace the transmission - the letter indicates that it has been remanufactured to the latest specification.
If the serial number is outside this range, do not replace the transmission. Submit a claim for the inspection only.
In all cases, the replacement transmission serial number must be captured for Jaguar's database. This bulletin contains specific instructions on how to enter this information based on your dealer management system: ADP, Reynolds & Reynolds. All other DMS systems do not support this functionality; use the DDW system to update a serialized component as described in attachment # 4.
Below is an example to assist in interpreting the serial number.
Example: 1X15384.
The first digit indicates the year of manufacture (Examples: 1 - 2001; 2 - 2002; etc.) The second digit/letter indicates the month of manufacture (Examples) shown.
The digits 3 - 7 are the running number of the transmission manufactured in the year/month given.
The example serial number was the 15384th transmission manufactured in October 2001.
The procedure for replacing the transmission inclusive of an oil level fill and check is included in this bulletin.
After completing the installation of the transmission, complete the "JATCO S941 Automatic Transmission Replacement Form" enclosed in the box. This form will accompany the returned unit back to the remanufacturer for review and or action.
<<<<<[/align][/align]
Old Mar 13, 2008 | 07:13 AM
ancientsanskrit's Avatar
ORIGINAL: ruslan35
Hey Dennis, this kinda of reports make me what to forget about doing anything with trany fluid. Even drain and refill doesnt sound too much fun anymore.
[sm=forgetit.gif]
Nah, I've been doing trans fluid fill/drains for years now. I've done it on vehicles with even weaker transmissions than the Jag. It's a very good procedure that incorporates putting fresher fluid gradually rather than all at once as Dennis has indicated.
I would do it in a heart-beat on the Jaguar if I only knew what fluid to use and where to obtain it.
Old Mar 13, 2008 | 11:46 AM
Dennis's Avatar
ud
If you find some JATCO fluid that won't require second mortgaging the house, let us know please.
Old Jul 18, 2013 | 07:40 PM
alan61's Avatar
I have took out the valve body and replace all 9 Solenoid also took out the top part that goes on the gears. Now you shift on R for reverse and it goes forward and keep on shifting down and it's go only forward. What did i do wrong trying to find a Diagram maybe i the switch plugs
Old Jul 23, 2013 | 12:35 AM
James Brandon Justice's Avatar
@Alan61
What needs to happen is you need to get a book on the transmission and see where you went wrong. Do a simple google search of "Technical Manual JF506E." I got my Technical manual from DISCOUNT AUTOMATIC TRANSMISSION PARTS, they were great to work with and the book was only $30.
Good luck,
Poet
Feb 7, 2025 02:18 PM
Marka
22
Sep 11, 2016 12:09 AM
dmatthewman
Sep 30, 2015 10:10 AM
Old_Doc
Sep 29, 2015 03:43 PM
