Transmission Question
Old Jun 9, 2014 | 11:12 AM
vai1953's Avatar
Default Transmission Question
I recently put a new front axle in on the passenger side. I had some fluid come out, it's dark and looks like it should be changed. Now I have a small leak coming out of the seal on that side. So I know I'm going to loose more fluid, putting the seal in. My questions are:
1. How much Trans fluid does the trans take, with or without the convertor?
2. What kind of Tranny fluid does it take, I was reading it has to be special fluid but no idea what kind. Dextran or Dextran 11 or what?
Thanks everyone for your help, if there are other things I should know please inform me. One other thing, under the battery is a very small cap is that were you put the fluid in? Where do you drain it from I couldn't find a drain plug.
Thanks again,
Vince
Old Jun 9, 2014 | 12:00 PM
santer's Avatar
This gives the lubricant types
http://www.bluejag.co.uk/lubricants-and-fluids.php
If you drain and refill then expect to get 3.5 litres out per drain
How To
https://www.jaguarforums.com/forum/x...ure-faq-43649/
As to capacity, this says 8.32 litres
https://www.jaguarforums.com/forum/x...nged-atf-1066/
Old Jun 9, 2014 | 07:31 PM
vai1953's Avatar
Thanks Santer, I'll look this stuff up. Looks like I have to order the seal too.
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
ahunt4
Sep 14, 2015 08:17 PM
AtholC
Sep 9, 2015 09:07 PM
