Trying to find a reluctor ring in the US
I have been trying to fix up an 02 Jaguar X type AWD wit a 2.5L V6 and I am down yo the last repair ( I hope). The drivers side rear ABS reluctor or speed ring is broken and I have removed all the parts. I am trying to find a replacement but, what I have found so far is overseas shipment or something that may or may not fit.
Is there a good source for the parts, or is there another compatible model to look for.
Any help will be appreciated.
Hank, while I will admit that it is a more expensive route to go, probably a better route if you ask me. You simply need to order a new half shaft for that side of the car. Sure, it is not a $5 fix, but with as many miles as that are on the car, this will be a good investment in the car to ensure it will last for a long, long time. The new half shaft will have the reluctance ring already installed for you.
In case you decide to go the cheap route, reluctor ring at Welshnet
The rear half shaft with reluctor ring is a little cheaper at SNG Barratt, $82 currently.
