Washer Fluid Warning Message
Old Nov 29, 2008 | 02:06 PM
Kevin93940's Avatar
Default Washer Fluid Warning Message
06 X-Type Sport. Bought the car new from dealer in August. 323 miles. Long story...
Just checking under the hood this am. The washer fluid reservior was bone dry. No signs of leakage. Looks like it may never have been filled. I have the Message Centre fitted - and I've never seen amessage that the washer fluid was low.
Could this be a malfunction with the sensor? Or, does the warning message not work if the bottle is completely empty? Or does it just give up after a while?
Thanks,
Kevin
Old Nov 29, 2008 | 04:04 PM
Dennis's Avatar
ud
Default RE: Washer Fluid Warning Message
Well there is in fact a fluid level sensor switch...It maybe disconnected..
Old Nov 29, 2008 | 08:29 PM
Brutal's Avatar
you can pull it out and check its operation, but its better thsn saying it empty when full, so whats the problem??????
Old Nov 29, 2008 | 08:53 PM
Kevin93940's Avatar
bojangles -
I can see the level easily in my car. The reservoir bottle is in the front left. Has a blue top with the little symbol for washer fluid on it. Right where the owner's manual says it should be.
I could post a pic - but its not empty any more. I filled it this morning.
The dealer is about five minutes from my house - so its no problem going back.
Old Nov 29, 2008 | 10:05 PM
Kevin93940's Avatar
OK, I get it...
I didn't measure - but estimating from what's left in the jug - I added about 1L of washer fluid - which filled the reservoir to just below the neck.
So, there was probably about 3L of fluid lurking around in there...
My owners manual says capacity of the washer fluid reservior is 4.2L.
No wonder the light didn't come on.
Thanks!!
aholbro1
Dec 29, 2024 06:46 PM
ericjansen
Dec 19, 2021 12:20 AM
picard
Oct 12, 2015 11:56 AM
pab
Sep 16, 2015 10:34 AM
Johnken
Sep 15, 2015 05:46 PM
