Water pump leaking?
Old Jul 30, 2009 | 02:21 AM
ptl's Avatar
ptl
Default Water pump leaking?
2002/3.0 92kMiles is losing coolant slowly. I detected that it's coming from the water pump's direction. I took a picture of the leakage. Would you guys say that the coolant is just collecting on this coupling (what ever it is) from the leaking pump or could it be this part leaking?
Thanks again in advance!
Old Jul 30, 2009 | 10:04 PM
poboyblues's Avatar
It's that part leaking. It's the upper hose/tstat housing assembly. Replace as necessary. Water pump is to the right and up from that housing. If water pump is leaking you'd see coolant on your transmission case.
Old Jul 31, 2009 | 02:36 AM
ptl's Avatar
ptl
Thanks for the info poboyblues! Nothing on the transmission case so I'll first take apart the thermostat housing and check the seals there.
Old Jul 31, 2009 | 09:30 AM
poboyblues's Avatar
I've never had luck just replacing the seals. But you can try.
Old Jul 31, 2009 | 03:27 PM
SMT's Avatar
SMT
Hi poboyblues, I have the same problem, it looks very difficult to get to, what would you do with it?
dsnyder586
Dec 29, 2024 07:39 PM
Jandreu
Jun 30, 2022 03:10 PM
Wahooesprit
Dec 23, 2019 02:01 PM
Saturbo
Sep 8, 2015 07:35 PM
