Water pump leaking?
2002/3.0 92kMiles is losing coolant slowly. I detected that it's coming from the water pump's direction. I took a picture of the leakage.
Would you guys say that the coolant is just collecting on this coupling (what ever it is) from the leaking pump or could it be this part leaking?
Thanks again in advance!
Would you guys say that the coolant is just collecting on this coupling (what ever it is) from the leaking pump or could it be this part leaking?Thanks again in advance!
Thanks for the info poboyblues! Nothing on the transmission case so I'll first take apart the thermostat housing and check the seals there.
