Weak alternator and oil leak
Old Mar 2, 2025 | 03:09 PM
Mr rx-7 tt's Avatar
Thumbs up Weak alternator and oil leak
I pulled the alternator out of the X-type yesterday and also as I had mentioned I had an oil leak. The oil leak appears to be from the valve cover gasket closest to the radiator. Both valve cover gaskets were replaced 8000 miles ago by a British car repair shop. Kind of hit and miss with them.
Two questions:
* Is the cylinder bank closest to the radiator the left side or the right?
* Is the 3.0 engine the same as the 2.5 as far as the gaskets?
https://www.partsgeek.com/catalog/20...er_gasket.html
Left side
Part Number: 651-07172833
Brand: Mahle
Right side
Part Number: 651-07315401
Brand: Mahle
Thanks in advance!
Old Mar 2, 2025 | 07:49 PM
Peter_of_Australia's Avatar
Part number: C2S27975
CAMSHAFT COVER GASKET - LH B BANK
X TYPE 2.5 & 3.0 V6 2001 to 2005 end at VIN E51583
__________________________________
Part number: XR851930 camshaft cover gasket RH A bank
  • Jaguar X351 XJ V6 2010>>>
  • Jaguar x350 XJ 3.0 V6 2003 to 2009
  • Jaguar S Type 3.0 V6 2002 to 2009 Fron Vin M45255
  • Jaguar XF 3.0 V6 2008>>>
  • Jaguar X Type 2.5 & 3.0 V6 2001 to 2009
______________
The radiator side on the X-Type is bank 2 (bank B) - LH
Old Mar 2, 2025 | 08:57 PM
Mr rx-7 tt's Avatar
______________
Thank you Peter.
Old Mar 4, 2025 | 05:30 PM
Mr rx-7 tt's Avatar
I picked up my alternator today and the gentleman who rebuilt it said oil ruined it. Anyhow, new gasket comes in tomorrow and I'll start the repair on Friday.
Old Mar 4, 2025 | 05:39 PM
NBCat's Avatar
I would encourage you to use the OEM cam cover gaskets and spark plug boss seals. I personally haven't had any luck with the aftermarket gaskets/seals as they're prone to premature failure.
Old Mar 4, 2025 | 10:46 PM
Mr rx-7 tt's Avatar
I ordered Mahle cam cover gaskets, Do you have any experience with them?.
Old Mar 11, 2025 | 12:14 PM
Mr rx-7 tt's Avatar
I also noticed the back cam cover (valve cover) is leaking, most definitely the aftermarket gasket seals didn't work.
DO NOT USE AFTERMARKET GASKETS, USE Jaguar OEM gaskets only.
Old Apr 4, 2025 | 02:51 PM
Mr rx-7 tt's Avatar
I had the alternator rebuilt as it failed due to oil damage. I replaced the front cover gasket as it was leaking and I will end up doing the rear at a later date.
Old Apr 5, 2025 | 06:30 PM
Mr rx-7 tt's Avatar
This is how bad the gaskets were leaking. The oil in the spark plug galley was a surprise.
MisplacedPriorities
Jul 4, 2024 10:37 AM
Justin4u973
Aug 7, 2023 11:24 AM
Leons
Jan 27, 2023 10:52 AM
afrimpong
Aug 19, 2020 06:01 AM
foxteca
Aug 21, 2014 03:05 PM
