Weird noises
Old Apr 7, 2008 | 05:55 PM
jagxtype's Avatar
Default Weird noises
Already tried search and didnt come up with anything despite remembering someone saying something about a 2.5L noise thread.
I have a 04 xtype 5 spd 2.5L with nearing 60k mi (and fast i might add)
In the morning when i start it up, it makes a rattling like sound that doesnt sound too appealing.
After that when i am in any gear, above 2400 rpm or so while accelerating, there is a noise that sounds a lot like heatshields rattling and louder the harder your accelerating. I have checked and all the heatshields are tight.
On top of that, my brakes squel 90% of the time that i am driving and squel even worse when i am taking left turns or vering left at just about any speed. The pads are fine and i took the what i beleive to be culprit caliper assy apart and lube it and it still did not stop. The sound gets louder when i very lightly press the brake pedal, but stops when i applymore pressure. It has to be the front too b/c when i pull the parking break up with some pressure the noise still does not stop. I had it in the *********** (deserves to be called this in this instance) and they said the usual "Thats just metallic compound in the semimetallic pads" since it was under warranty. I did notice that it still has the original bosch pads on it and are in great condition for the most part.
These noises make this car sound like a old beat up jalopy and its pissing me off like no other. If anyone can help i would appreciate it. FJT??? where are you, you seem to always come to my rescue
Old Apr 7, 2008 | 05:57 PM
FactoryJaguarTech's Avatar
Default RE: Weird noises
You said ***********
Old Apr 7, 2008 | 05:58 PM
Can you post video of the car driving by slowly for the squeel noise?
Also same for the rattle noise.
Need to hear them on this one I am afraid.
Old Apr 7, 2008 | 06:03 PM
jagxtype's Avatar
i will see if i can get one of my buddies to video tape it. The slowest i can go is 1st gear above 2400rpm and the squel is the brakes, just not sure why. In theory, i bet beveling the edges of the pads slightly would stop it.
The clutch used to make weird noises engaging as well, but that quite. Also it used to pop under a load especailly in reverse before the transfer case was replaced and now thats back. I am wondering if the rattling is the TC again???? If so what is warranty on replaced parts?
Old Apr 7, 2008 | 06:05 PM
12 months 12500 miles I believe.
Did I give you the info on the noises for X-Types? The bulletins?
Old Apr 7, 2008 | 06:08 PM
jagxtype's Avatar
no sir. Please enlighten me.
Old Apr 7, 2008 | 07:58 PM
jagxtype's Avatar
FJT, you motorboating son of a buck...where'd ya go?
Old Apr 7, 2008 | 09:15 PM
pm me your email address
Poet
Feb 7, 2025 02:18 PM
sadepol01
16
Nov 22, 2024 05:05 PM
JimC64
31
May 30, 2016 03:04 PM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
