What kind of fluid to run in transfer case?
Old Dec 17, 2012 | 07:41 PM
Lcgi's Avatar
Arrow
Originally Posted by pab
Wow, the underside of your car is clean!!!
Must be not picking up all the gunk that gets deposited on winter roads (unless you had it steam cleaned before starting your task...)
Glad it worked out for you.
Jaguar - it's not an automobile, it's a Motorcar
Pab,
No prior steam cleaning was done, its in its normal/original condition...... yes, the Aussie climate (urban areas at least) is much kinder to Cars - which is why you will find many cars on the road here that are 20+ years and most in good condition.
Cheers,
Old Jan 24, 2013 | 10:14 AM
bdelgros's Avatar
Why can't you just add to your transfer case oil? Draining it seems to be complicated, its not like engine oil, it is just gear lube. For all I know the transfer case could be empty?
Old Jan 24, 2013 | 01:06 PM
pab's Avatar
pab
Because, without opening it up and letting what's in it drain out, you have no way to determine how much is in there (it only has a drain plug on the bottom). So just drain it and refill with new fluid.
Old Feb 11, 2013 | 09:56 AM
tjandy's Avatar
Awesome thread, thanks for the help. Did this yesterday, used Mobil 1 fully synthetic 75-140
cissdm
May 3, 2016 06:02 AM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
sogood
Sep 15, 2015 07:35 AM
luc891
XE ( X760 )
Sep 15, 2015 12:30 AM
john_cook12
Sep 9, 2015 03:47 AM
