When your Jag overheats in traffic!
Old Feb 12, 2013 | 06:09 AM
Dent3's Avatar
Default When your Jag overheats in traffic!
My cars engine overheated this am. Need to replace thermostat and electric fan unit the dealer says. Cost R 8800! Is this really the cost of these parts? I have a Jag xtype 2005 model
Old Feb 12, 2013 | 07:15 AM
Welcome to the forum Dent3,
I've moved your question about the Thermostat and Fan to the X-Type section.
You'll get opinions and advice on the estimated cost here from members with the same model. (conversion rate today gives SA Rand 8800 = $980 = £628)
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
Old Feb 12, 2013 | 01:15 PM
tanis8472's Avatar
Thermostat about £25 here and about an hour labour.
So about £550 for fan unit
Old Feb 12, 2013 | 02:08 PM
astromorg's Avatar
I think it would be unusual for both the fans and the thermostat to fail at the same time.
Why not start by checking the fuses for the fans - F16, 5A in the Engine Compartment Fuse Box and F40, 80A, fitted to the underside of the same fuse box - more difficult to check, but use a meter to see if there's power at the fans when they ought to be running.
Then change the thermostat to see if that's the cause.
Then look for a used/second hand fan unit if that's what's needed.
Raul Lara
Sep 14, 2015 07:31 PM
dickc
Sep 8, 2015 08:15 AM
MrMellor
Sep 7, 2015 10:22 AM
Raul Lara
Sep 2, 2015 05:23 PM
