Where to buy? - Auxillary power socket C2A1403
Old May 25, 2013 | 05:33 AM
jackpea's Avatar
Default Where to buy? - Auxillary power socket C2A1403
Hello
I am after the following part number from a jag parts specialist, unfortunately everyone I phone no longer has these in stock so I was hoping that somebody on the forum may know of somewhere that has these in stock? Long shot I know
Here's the part
JAGUAR AUXILLARY POWER SOCKET C2A1403 in Accessories
Old May 25, 2013 | 06:42 AM
TreVoRTasmin's Avatar
I think you may be out of luck. Tried searching on www.partsvoice.com for ya but no dealers showed up having it in stock. First time I've come across that!
Originally Posted by jackpea
Hello
Here's the part
Old May 25, 2013 | 07:06 AM
try jagbits - shows in stock for $103
http://www.jagbits.com/mm5/merchant....t_Code=C2A1403
Old May 25, 2013 | 08:26 AM
WhiteXKR's Avatar
Get a decent quality socket such as : Marine Grade Cigarette Lighter Socket 12 VDC : Amazon.com : Automotive and wire it in yourself.
Old May 26, 2013 | 04:20 AM
jackpea's Avatar
Thanks for the responses guys, appreciate it.
I ended up removing the 3 prong connector and wiring up myself, working great so far.
Old May 26, 2013 | 06:34 AM
Graham Royls's Avatar
Default Wiring in adapor
@ white XKR
are there details/pics for this wiring job?
Old May 26, 2013 | 09:41 AM
jackpea's Avatar
Originally Posted by Graham Royls
@ white XKR
Graham I should imagine that cigarette socket has a neutral and positive connector. At the back of your jag in the boot underneath the carpet to the left (mine is right hand drive) you will find a three prong male adapter (it looks like a female because it has a cap on the end). It will have three wires going into it a brown, brown with green stripes and a black.
Brown is always live straight from battery
Brown with green stripes is live when the ignition is on
Black is neutral.
Hope this helps
Old May 28, 2013 | 05:58 AM
Default Boot wires
[QUOTE=jackpea;744144]Graham I should imagine that cigarette socket has a neutral and positive connector. At the back of your jag in the boot underneath the carpet to the left (mine is right hand drive) you will find a three prong male adapter (it looks like a female because it has a cap on the end). It will have three wires going into it a brown, brown with green stripes and a black.
Black is neutral.
Txs for input
Have a plug as described however wires are
Blue and yellow
w Brown and green and Black . would the blue and yellow be equivalent of your brown?
also a separate small 2 prong female wire blue and white for?
Old May 29, 2013 | 12:49 PM
jackpea's Avatar
Hi Graham
Can you post a picture?
aholbro1
Dec 29, 2024 06:46 PM
Dimitrigregorio
17
Sep 5, 2019 03:47 AM
jagent
Sep 12, 2015 01:40 AM
iownme
Sep 11, 2015 02:57 AM
MrMellor
Sep 7, 2015 10:22 AM
