Why my car start off slow in first evry day but after fine?
Old Jul 16, 2011 | 09:51 AM
zibby_uk's Avatar
Question Why my car start off slow in first evry day but after fine?
hi my x-type for the last few days when i start it first time it takes 2 to 3 seconds to start up but after all day normal,
its not normal. Normally its starts straight away.
I know alot about jaguars but i have never had this problem before now i need help.
1st thing battery: the running battery watt is 14v not running is 12.7v thats ok
fuel pressure: 4.5bar as the jaguar techs state should be for this model
fuel filter is new
injector: just cleaned last month
spark plugs: six months before i cleaned all with brush and remove carbon the spark plugs should be safe
Idle Air Control valve is clean
i have disconnested battery and reconnected it,
this problem has occured in the last 3 days, i usually am doing something to car every other week to see and check everything under the bonet
Can anyone help me with this problem? thanks
Attached Thumbnails Why my car start off slow in first evry day but after fine?-cimg4996.jpg
Old Jul 18, 2011 | 11:12 AM
kaniela's Avatar
im a little confused. your topic is distorted and the first sentence in your post isnt clear. if you mean that once you click your key all the way to start your car it takes a few seconds for it to grab and start your motor then it runs fine all day after you have run it then here is my suggestion.
1) wait a few seconds when you click the key 3 clicks right before you engage the starter. it gives time for all the electrical currents in your car to make connections. then start it and see if it starts right up. if so, then you know your problem... youre in to big of a hurry to get to the titty bar to start your car correctly.
2) it might be cold or hot in your region and that effects starting as well as if it rains, morning dew, garage kept or street parking etc. ya know?... earthly elements.
3) what have you done different recently? you say you work on your car frequently. what have you done recently that might have caused this. Where you park, different gas stations, additives, letting the wife drive, aftermarket parts, etc. try those things first before spending money trying to diagnose something that might be as simple as not putting your car cover on before you go to sleep.
BrentGardner
29
Dec 16, 2024 12:13 AM
Paradigm
Jun 15, 2019 05:59 AM
Jaguila
Sep 5, 2015 06:16 PM
1964Daimler
Sep 2, 2015 11:41 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
