Will an '05 transmission fit my car?
Old Aug 30, 2012 | 05:53 PM
mckeehan6419's Avatar
Default Will an '05 transmission fit my car?
I have an '02 X-Type Sport, 3.0L, with auto trans that has lost reverse. The new trans and install is looking like $4800.00. So, I start looking at used boxes and find one with 27K on it for a grand that came from an '05, 3.0L auto. Will it fit and is it worth the risk? $2200.00 vs $4800.00. I think I'll have him do the oil pan gasket while he is in there....any other suggestions? Also, the car has 102K miles, but doesn't seem to have another problems.
Old Aug 31, 2012 | 01:29 AM
disguay's Avatar
The only thing that could be the problem is that the transfer cases were switches from and old style in 02-03 to a new style in 04+. I would expect that all the transmissions will fit because all transfer cases fit, and all engines fit. If you catch my deductive reasoning, there is no reason it shouldn't fit unless they have changed the TCM connectors or something.
Old Aug 31, 2012 | 04:57 PM
Thanks, I didn't even think about the TCM....guess I'll investigate that too.
Old Sep 11, 2012 | 03:54 PM
Default It worked
Well, I get the trans from the 05 for $800.00. It fit perfectly, the the old transfer case worked with it, it programmed perfectly, and for an extra $400 the shop installed a new oil pan and gasket. With labor, parts, and fluids, I'm back on the road for $2200. So, the answer to the question is yes, the newer trans will fit an 02 as long as it is past VIN C79329. The trans for a car before C79329 seem to be a little harder to find, so I got lucky.
BrentGardner
29
Dec 16, 2024 12:13 AM
Isoruku
Jun 19, 2020 12:54 PM
SatanClaus
Aug 29, 2015 09:15 AM
Aegis21
Aug 27, 2015 08:30 AM
dpappyp
Aug 27, 2015 06:31 AM
