Windscreen Washer - Adjustment? - FIXED
Old Mar 16, 2012 | 12:46 PM
Lcgi's Avatar
Arrow Windscreen Washer - Adjustment? - FIXED
Howdy,
Are there any provisions to adjust the aim of the windscreen washer jets?
On mine, the drivers side aim is OK, but the passenger-side jet hits the windscreen about 2-3" down from top (with most of the fluid - going over the roof)
all help to cure this - much appreciated
Old Mar 16, 2012 | 09:48 PM
billbjork's Avatar
Default washer spray head
I don't think there is a adjustment as they are solid to the hood (bonnet), could be possible that the sheet metal on that side is distorted a fraction. At that distance only a slight degree could throw the trajectory off and at road speed the air travel will do the rest. Also blow out that side with low air pressure, could possibly have a orifice that is partly plugged. I have seen orifices that are plugged spray 45 degrees. could have picked up debris from the reservoir.
Old Mar 18, 2012 | 02:05 AM
Lcgi's Avatar
Arrow
Hi Billbjork,
OK...I had a close look at the offending passenger-side Screen Washer Jet
What I found is there are two nozzles in each of Washer Heads. Taking a small safety-pin and inserting the point into each nozzle I discovered (to my pleasure) that each nozzle fits into the head via a ball-joint... and so, the nozzle(s) can be infinitely adjusted for both vertical and horizontal trajectory.
Therefore, after a little re-aiming - the problem is now solved and fixed !
Maybe this post should go into the section; "I didn't know my X-Type did that"
Cheers,
Larry
Old Mar 18, 2012 | 04:43 AM
Cadillac's Avatar
LOL, good to see it was a cheap fix
aholbro1
Dec 29, 2024 06:46 PM
Richard_gib
Sep 12, 2015 07:08 PM
jagent
Sep 12, 2015 09:10 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
Tar
Sep 6, 2015 11:24 AM
