X-Type 2.5 2002
Old Jan 20, 2016 | 08:30 PM
hanky's Avatar
Default X-Type 2.5 2002
Car was running fine turn it off, came back turn it on it started but all the lights on the dashboard came on, turn it off immediately and tried to turn it back on turn ignition switch but car is dead engine do not crank at all, any leads of what that could be thank you
Old Jan 21, 2016 | 01:17 AM
JagV8's Avatar
Dead battery
Old Jan 21, 2016 | 02:43 AM
Originally Posted by hanky
....... any leads of what that could be thank you
Welcome to the forum hanky,
I've moved your question from General Tech Help to X-Type forum. This is the place to post technical questions about your model.
Old Jan 21, 2016 | 06:48 PM
hanky's Avatar
thank you
Old Jan 21, 2016 | 06:55 PM
hanky's Avatar
Default x type 2002
Originally Posted by JagV8
Dead battery
reading the forums i thought that will be the case took battery out and get it to auto zone they checked it and charged fully tests came good battery, went and connected back, tried again but with no results key turns lights in panel come but when turn the key nothing happen, also i close the door and press the brake pedal. any other suggestion, they are telling me it could be the alarm i is there any way to disconnect the alarm
Old Jan 21, 2016 | 07:45 PM
DPK's Avatar
DPK
The Inertia switch may have popped out and needs resetting...It kills the car's electrical run system during an accident.
The switch is located on the passenger side front right foot wheel. Open the door and get down and look to your Right. it will be to the right of where the passenger would put his/her feet. There's a plastic piece of trim that will look like it has a little plastic piece . Remove that piece of plastic and push the switch in.
Old Jan 21, 2016 | 08:55 PM
hanky's Avatar
thank you, ill try that hopefully that is the case, but the car has not been in an accident
Old Jan 22, 2016 | 01:25 AM
JagV8's Avatar
If it's the alarm (unlikely) it puts out a flash code on the PATS light.
Could be a dead starter or lack of power to it, but usually it's a battery said to be OK that isn't. Check actual voltage with a heavy electrical load.
Old Jan 22, 2016 | 07:27 AM
DPK's Avatar
DPK
When the auto store here in the US tests the Battery, they put it under load as part of the test.
Old Jan 22, 2016 | 02:51 PM
joesoap's Avatar
If not battery/starter!!
If auto look at lockout on changer? try it in Park.
aristabarret
Feb 27, 2016 04:35 PM
raywilcauskas
Jan 26, 2016 12:22 PM
steveperry
Jan 22, 2016 03:32 PM
permont
Jan 19, 2016 05:10 PM
badboy
Jan 17, 2016 09:41 AM
