x type 2007 screen went black
Old Nov 28, 2014 | 01:55 PM
lino miguel's Avatar
Default x type 2007 screen went black
any one one can help with the s/w software...? My screen went black
Thanks,
Old Nov 28, 2014 | 02:29 PM
Welcome to the forum lino miguel,
I've moved your question from General Tech Help to X-Type forum where I see you have already posted the same question in an existing thread. Members here with the same model will be able to help if you give them time to reply.
Old Nov 28, 2014 | 04:03 PM
Paulc732's Avatar
here you go.
https://www.jaguarforums.com/forum/x...d-link-131478/
Old Nov 28, 2014 | 11:22 PM
Thanks Graham... Done
Old Nov 28, 2014 | 11:24 PM
Thanks for your help Paulc732.
When I followed the link, says: 404 - We can't find what you're looking for.
Old Nov 29, 2014 | 10:43 AM
Paulc732's Avatar
Sorry the link timed out here it is.
https://www.dropbox.com/s/eln51a0gy9...ADING.KWI?dl=0
Old Nov 30, 2014 | 05:32 AM
Many Thanks Paulc732. Unfortunately still no joy... I inserted the burned dvd and waited for more than 10 minutes and nothing. Keeps flashing 50 and 51...
Old Nov 30, 2014 | 10:44 AM
Default X Type screen went blank
Old Dec 1, 2014 | 01:36 PM
Default X Type 2007 Black Screen
Anyone can help... Nothing is working and displays codes 50 & 51...
Heating set and cant get rid of....
Old Dec 2, 2014 | 05:24 AM
Paulc732's Avatar
Miguel,
how did the screen go blank?
did you start the car one day and it was blank or did you go into the system and press the update button?
if its the latter then the Loading .KWI file should resolve the problem.
if it just went blank during normal use you are probably looking at a hardware issue like a bad dvd player or wiring.
We know you have power going to the Dvd player as you were able to load the disk.
one thing to try that has worked for others is disconect the negative terminal of your battery for a couple of hours. with the LOADING.KWI disc still in the drive.
then reconnect the battery turn on the ignition and wait the 15 mins.
if the 50-51 does not display this is a good sign that the file is loading.
good luck and keep us posted
Old Dec 2, 2014 | 11:06 AM
Miguel,
Hi Paulc732,
Above all, many thanks for trying to help me out… (I am going crazy with this…)
I bought the car on Friday and the garage from where I got it was unable to give me the code for the radio system as it was required on the display. They advised me to go to Jaguar or get it from the internet. I went to Jaguar and the code they gave me was not working. (Being told that the radio was probably not the original and I have to dismantle the thing to get the number from the back)… What I have done… I went to youtube and get a way of pressing multiple keys to go to the system… The last thing I do remember was to press a key on the display saying (S/W) ??? Since then, the screen went black and started flashing (EXT 50) and (51) alternately… I didn’t know what is going on until I joined this forum and recognized the numbers were codes… To increase the problem, my heating was set to high and now I have no chance to turn it off and I have to drive with the windows open, (otherwise, I will roast…)
I tried what you suggested and I left the car with no battery for 3 hours… Still the same !!!  I have disconnected the battery again and I will leave it all night… I will repeat the step tomorrow…
Once again, many thanks for your help… (That is good to have it once we are so desperate with the cars…)
Hi Paulc732,
I tried what you suggested and I left the car with no battery for 3 hours… Still the same !!! I have disconnected the battery again and I will leave it all night… I will repeat the step tomorrow…
Old Dec 3, 2014 | 07:26 PM
Paulc732's Avatar
what software did you use to burn the LOADING.KWI file?
I know personally that it works with Roxio (just an fyi)
I know others on here have had success with other "free" software check the thread on blank nav screen.
Old Dec 4, 2014 | 10:07 AM
djfedja's Avatar
Hello, I again for jaguar ext 50 51 workshop was they tried to put the blame did not find any other navigation discs also did not help that I have Kwi file recorded 10 DVD disks and nothing happens. jaguar center said that they do not know what's wrong and work hour costs 50 euro + - repair the day but that is not guaranteed to find fault. I maybe wrong article, I use to drive powersio program and the article as a data cd / dvd probability to be written differently maybe need another file? please help
Old Dec 13, 2014 | 03:28 AM
Hi Paulc732!
Many Thanks for all your help!
I just swapped the DVD and all done!
Its asking now for the SYSTEM PIN...
I will try to see if anyone can help!
Miguel
Old Dec 14, 2014 | 07:36 AM
Paulc732's Avatar
Hi Paulc732!
Miguel
Glad to hear it worked for you, sorry I cant help with the code as it is not required over here in the States. Your Jag dealer should be able to look up the code for you.
Old Dec 14, 2014 | 08:02 AM
your help was well above the roof! Thanks Paulc732 !!!!
stanjag
Dec 29, 2024 08:26 PM
Nati
May 16, 2020 08:30 AM
GreyXK
Aug 31, 2015 05:15 PM
Javier Cepeda
Aug 29, 2015 12:50 PM
Terrance Williams
Aug 26, 2015 11:50 AM
