X-Type electric steering column?
Old Aug 19, 2016 | 01:12 AM
GeorgioTsukolius's Avatar
Default X-Type electric steering column?
Is the steering wheel lock on the X type mechanical or electric, I can't find a good straight answer.
Old Aug 19, 2016 | 11:02 AM
avern1's Avatar
The steering lock itself is mechanical. It does not engage until the key is removed from the ignition. With the key inserted you should be able to rotate the steering wheel. With the key removed you can not rotate it.
Old Dec 9, 2016 | 09:31 PM
Thang Nguyen's Avatar
Well the locking is mechanism, but I think Georgio question is it activated by electrical or by engaging by mechanical components.
Old Dec 10, 2016 | 05:26 AM
astromorg's Avatar
Why not disconnect the battery and see what happens?
Old Dec 10, 2016 | 08:16 AM
avern1's Avatar
I recently was changing the upper radiator hose and needed to hard over the steering wheel for access to the screws on the inner wheel arch. With the battery disconnected the steering wheel was still MECHANICALLY locked. I had to unlock it with the key to turn the steering wheel.
Old Dec 10, 2016 | 10:59 AM
So the key insert and turn to unlock the steering wheel without battery connect, that mean it was mechanical lock and unlock, but if you inserted the key and turn, if the wheel can not turn without battery connected, that's mean it was electrical activated. Period.
Alli Quinninho
Dec 22, 2020 03:00 AM
kreyszig
Apr 14, 2016 04:42 AM
JackJohn
Mar 28, 2016 08:59 PM
Humy
Oct 8, 2013 10:38 AM
chprman
May 1, 2008 05:23 PM
