X type front door latch stuck
Old Dec 28, 2010 | 04:53 PM
Thermo's Avatar
Veteran: Navy
DrDee, I would try spraying the latch mechanism with a healthy dose of WD-40. You may have gotten a little bit of sand/dirt into the mechanism and it is binding it up. By getting a good bit of WD-40 into the latch, you can flush this stuff out. Keep in mind that what goes in, must come out. So, you may want to put a little bit of newspaper or other catch device under the door to catch what drips out. There are drains on the bottom of the door. You can see them if you look on the underside.
Old Dec 29, 2010 | 06:13 PM
Mike X's Avatar
My 02 X -Type does the same , I use the key in the lock a couple of times , usually clears it , so far .
Old Dec 29, 2010 | 06:50 PM
Hey DrDee....have you looked at the X type quick FAQ link thread? It will be worth checking out for sure
There's also a few discussions on door locks/ handles issues as well as a very good how to on removing the door card for a good look to see whats going on....
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Trujillo D. Joseph
Oct 18, 2019 03:55 AM
91xjscoupe
Sep 1, 2015 12:01 PM
anthem
Aug 31, 2015 02:01 PM
