x type headlamp surgery
Old Jan 23, 2010 | 04:20 PM
chumberson's Avatar
Default x type headlamp surgery
Dear Fellow Xtypers;
After being told that my low beam headlamp socket was melted and could only be repaired by replacing the entire headlamp assembly, at a seattle cost of $660.00 plus labor, I got the idea of by-pass surgery from this forum. At a cost of $12.00, total, I got a H1 assembly from e-bay and then two .30 cent female connectors; an hour at most:
It worked beautifully.
Requires taking out the battery for easier access. THanks to the forum for saving my wallet over $1200.00
chris@seattle
Old Jan 23, 2010 | 05:28 PM
Brutal's Avatar
there a service fix for that and supplied jag connectors. but Xtype headlights suck. you look at them wrong and the plastic adjuster posts inside break. I just threw 20 out. I gave up a finding a good long lasting repair, they need to have metal posts instead.
Old Jan 23, 2010 | 07:41 PM
Thermo's Avatar
Veteran: Navy
Brutal, if you are going to throw any more of the headlight assemblies away, could I get a left and right headlight from you? I will pay for the shipping. I have an idea for a set of X-Type headlights and would like to get a pair to play with. I don't care if the adjusters are broken or not. I will fix that once I get them apart for the modification. let me know if this is possible.
Thanks.
way2far
Aug 31, 2022 09:26 AM
ZJag
26
Sep 5, 2016 03:33 PM
raffoulig
Sep 8, 2015 01:56 AM
KarimPA
Sep 3, 2015 07:32 PM
dcvickers
Sep 2, 2015 06:14 PM
