X-Type with manual transmission sometimes Jerks at 3000rpm, and at 1/4 tank
Old Nov 18, 2009 | 12:45 PM
BuckMR2's Avatar
There will be codes stored as the MIL light did come on
Even if no MIL light comes on codes can still be stored as not all codes illuminate the MIL
Old Nov 18, 2009 | 09:04 PM
Oldengineer's Avatar
The 03 X-Type I used to have developed the occasional jerk at low fuel levels like yours. The car uses 2 fuel pumps - 1 to supply the engine, and 1 to transfer fuel between the 2 sides of the saddle type fuel tank. I suspect your transfer pump has a problem. On my car, in addition to the jerk problem, my tank fuel level sending unit went bad. The dealer replaced the pump/sending unit assembly under warranty, and, that solved both problems.
Regards:
Oldengineer
Old Nov 21, 2009 | 12:28 AM
rosemont83's Avatar
The cruise not available light is most likely a leak from the pcv hose and/or the two seals at the back of the engine on the passenger side on the intake manifold. Check the hose at the front of the engine under the jaguar cover
Old Nov 21, 2009 | 07:06 AM
BuckMR2's Avatar
Heres a pic...common problem new hose very cheap from dealer and much improved
Old Nov 21, 2009 | 09:00 AM
dennis black's Avatar
20 Year Member
read my thread (its long) but you will find it ...the thread is
(my x-type projects and installs)
i have a write up on your problem...very simple resolve to your problem
theres photos to help you pin point your problem..were here to help
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
KarimPA
Sep 3, 2015 07:32 PM
XFR_Gold
Sep 2, 2015 12:24 PM
