X-Type oil pan removal
Old Mar 4, 2012 | 01:58 PM
tomgee111's Avatar
Smile X-Type oil pan removal
The hidden single bolt that looks impossible to unscrew can be extracted without drilling holes or disassembly. I was able to extract it by bending my 10 MM open end a bit. Was then able to get the tip of the wrench onto the head of the bolt at almost a right angle but was enough of a “bite”. I used vice-grip pliers on the leverage end to turn the wrench and whoopee—it broke loose. Once it was loose, was very easy to spin it out the remaining way.
I plan to replace the bolt with a Phillips head, should make it quite easy to replace and extract again. Hope this helps----Chow
bamforp
Aug 14, 2024 05:36 PM
cissdm
May 3, 2016 06:02 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
avern1
Sep 6, 2015 04:22 PM
Dymaxxion
Sep 4, 2015 02:40 PM
