X-type sport wagon (2004) stuck in park?
Old Sep 28, 2016 | 10:50 PM
Patonage's Avatar
Default X-type sport wagon (2004) stuck in park?
I've read through the forums and can't find this problem.
My car is stuck in park. With the break off, the safety lock is engaged as it should be and doesn't budge. With the break down the safety lock disengages and I can move the lever as far as it being in reverse with resistance but the R doesn't light up and gears don't change. The P lights up. No engine lights or codes.
Any suggestions?
Old Sep 29, 2016 | 06:39 AM
swingwing's Avatar
Sounds like a shift linkage problem - either at the gear lever end or at the transmission. I believe you'll be able to see the transmission connection underhood, but you may have to remove the battery. If it's the gear lever end you'll have to access the mechanism in center console.
absoluteze
Apr 26, 2024 10:02 AM
95 Cat
Sep 9, 2016 08:53 AM
rhscare
Sep 6, 2016 05:46 AM
Johnny_B
Sep 5, 2016 10:00 AM
jpitma1
Sep 1, 2016 01:35 AM
