x-type wagon middle seatbelt retractor jammed
Old Apr 9, 2013 | 10:30 PM
rwcmick's Avatar
Default x-type wagon middle seatbelt retractor jammed
any thoughts on how to unstick it? rear seat, middle passenger, stuck in the fully retracted position. flipping seat forward, patting the seatback, nothing helps. i can't even figure how to open up the seatback!
here is a thrilling video of me fighting with the belt (spoiler alert: it wins)
Old Apr 10, 2013 | 11:59 AM
astromorg's Avatar
Is that not because the seat back has not been properly locked in the upright position?
Old Apr 10, 2013 | 12:14 PM
mjtemple's Avatar
The manual states there is an interlock between the centre seat belt and the seat latch; if the catches are not locked correctly, the centre seat belt will not operate. Rather than the seltbelt being at fault it might be that the seat isn't locking properly. You might need to slam the seat back in place.
File Type: pdf
Old Apr 10, 2013 | 02:54 PM
rwcmick's Avatar
thanks for the hints. the seat is latching very nicely. no wiggle once it is latched. there are no obstructions. the latch button looks the same as on the other side. it seems like the interlock is broken?
Old Apr 11, 2013 | 11:33 AM
rwcmick's Avatar
Well I have tried a lot of slamming the rear seat. No luck. The latching mechanism seems perfect, so there must be an issue with the interlock. Getting a lot of open ended quotes from mechanics that sound really scary. I'd like to tack on my own. Has anyone disassembled a rear seat on one of these wagons?
Old Sep 10, 2013 | 11:59 AM
DrkNyte's Avatar
Hi I know it's been over a year but were you able to resolve the center rear seatbelt issue? I have the same exact problem.
Thanks,
Old Jan 24, 2014 | 09:43 PM
hammo's Avatar
Left rear seatbelt may be wrapped around metal lug, preventing proper latching. Make sure left rear seatbelt is free from lug and close gently. Centre belt then functioned normally. Worked for me.
Old Sep 4, 2015 | 11:12 AM
hellokitty's Avatar
Thanks for the info(4 years later i know), i have also had the same problem,so after much fiddling decided to check it out on the forum,...... and once again Granny will be able to come with us Cheers!
nige
Paora
Feb 4, 2021 12:36 AM
vwbusbits
Oct 13, 2015 03:43 AM
n8ertot
Oct 11, 2015 02:28 PM
millertic
Sep 30, 2015 08:11 PM
