X-Type wheel dilemma
Old Aug 14, 2010 | 09:03 PM
Krazynate2100's Avatar
Default X-Type wheel dilemma
Hello all... I am a new first time Jag owner of a 2004 X-Type 2.5 5 speed. I'm having a hard time finding some steel rims for that car for the winter. I'm aware that the wheels are 16"x6.5" with a bolt pattern of 5x108.... What I would like to know is if it comes down to it... would I be able to take some steel rims that are the same size and bolt pattern from the likes of a Ford Taurus/Mercury Sable, Ford Crown Vic, or some Volvos and use them on the X-Type with some winter rubber?
Old Aug 15, 2010 | 07:47 AM
Thermo's Avatar
Veteran: Navy
Nate, looking online at the specs for the wheels for each car, yes, you should be able to use a set of rims from off of a Taurus. They will have roughly the same offset (varies from rim to rim, so, make sure for the specific set of rims you are looking at) and the bolt pattern is the same. If you stick with a 6.5" wide rim like what is factory on the X-Type, you should be good.
Old Aug 15, 2010 | 09:21 AM
Good deal. Thanks... That saves me from having to buy some budgie alloys to drive around in for the winter.
H20boy
Dec 24, 2024 03:23 PM
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
