X-type won't start
Old Jun 24, 2016 | 04:10 PM
Cà ptáin David Bekoe's Avatar
Default X-type won't start
Hey guys.. In new to this forum so hoping I'm in the right place.. I have a 2002 X-type and a few weeks ago the battery light came on and after parking for a while just went off by itself. A few days later I'd be driving and the engine would cut off for a second or two then continue. Today I was driving and it cut of and wouldn't start, the dashboard light barely illuminate and I though it's the battery but after swopping it out with another working battery it's stil not starting and the cabin lights seem low and flickering. Has anyone ever had this problem and what should I do?!!
Old Jun 24, 2016 | 05:00 PM
Larry-Cleveland's Avatar
1. I would make sure the battery is charged.
2. remove and clean clean both ends of both battery cables
3. use a set of jumper cables to bypass the battery cables, the cables go bad on this car too
Old Sep 27, 2016 | 11:05 PM
Thang Nguyen's Avatar
You said:"...another working battery.." Working battery is not good enough! X-Type need GOOD battery. Did you check the voltage of the "working battery"? If it below 12V it's not good.
ImNotFamousAnymore
Feb 12, 2026 06:38 AM
DJS
May 23, 2017 04:37 PM
Slow
Apr 10, 2016 04:10 AM
NW1996
Apr 3, 2016 06:56 AM
Dean Kitching
Mar 30, 2016 02:53 PM
