XE ( X760 ) 2015 -
17 XE Diesel ready to buy
Old Jul 2, 2022 | 10:11 PM
Skycrane's Avatar
Default 17 XE Diesel ready to buy
Hey guys, as the title says I'm about ready to get my first Jag. I've has 2 Mercedes an 88 300sdl, and a 94 300d and ran them in the ground and put over 200k on each. Then I got an Audi A3 TDI that the trans died at 350k, that was my daily 150 mile driver
So looking at used cars today I came across the Jag, I wasn't looking to spend 25grand on one, but its got less than 30k miles on it, and was a really sweet ride with enough power to play with.
So what are yall,s thoughts on it? Can I put 250k on the car How easy is it to replace the brakes . Is there any expense repairs that need to be scheduled, in the audi at 120k I had a trans service and timing belt/water pump repcement that was about 1800 usd every time
Thanks for the help in advance
Old Jul 3, 2022 | 06:33 PM
2018XF25T's Avatar
There are reports of timing/chain belt breaking/snapping on Diesel Ingenium engines 2.0 turbo causing engine failure. To prevent this from happening, have the timing/chain belt replace every 60K miles and you're good to go.
This has a Turbo engine. I would suggest as well doing some research on basics to prolong the life of your car's Turbo engine. There are several videos on YT, Do's & Don'ts about Turbos. Good Luck
Old Jul 3, 2022 | 06:45 PM
Skycrane's Avatar
Originally Posted by 2018XF25T
There are reports of timing belt breaking/snapping on Diesel Ingenium engines 2.0 turbo causing engine failure. To prevent this from happening, have the timing belt replace every 60K miles and you're good to go.
Well thats not to bad u guess, I hope I can find an independent shop that works on Jags. With a good maintenance schedule do you think its possible to get 200k miles out if the car?
Old Jul 3, 2022 | 09:55 PM
2018XF25T's Avatar
Here's what you should do, I am keeping my Jag with Ingenium engine 2.0T (Petrol) for a long time. I am doing an OCI of 5K miles way shorter what Jaguar's OCI recommendation. Plus, I don't need to buy the Jaguar's recommended oil. Any top tier oil brand will do. With this method I am prolonging the engine parts, also the timing chain and the Turbo.
With proper maintenance and care you're Jaguar will last a lot longer than what you expected. The car's engine also depends on the user's driving habits
Something to read about Ingenium engines:
https://www.rmagroup.net/all-news-up...-top-10-world/
Old Jul 4, 2022 | 03:55 AM
Fraser Mitchell's Avatar
There is no timing belt on the Ingenium engine, it is a chain with the normal tensioner. However the report of early failures is correct. Later Ingenium engines have modified parts, (from about 2019, I think). These can be fitted to earlier engines. Replacement is not an easy job, because the timing chain is at the rear of the engine, next to the flywheel, so as a minimum, the gearbox must come off, to get at the back of the engine.
This position for the timing chain is not unique, and I understand one or two BMW engines are similar.
Old Jul 26, 2022 | 03:28 AM
macribor21's Avatar
I've got the petrol V6. It's been a gem. I would not get a diesel unless you do long trips everyday. Otherwise I've heard only bad things. Sorry to say, I love Jaguar and the XE in every way though. It's a brilliant daily.
ryan.kent221968
XE ( X760 )
Aug 17, 2021 03:53 AM
Leviathan123
XE ( X760 )
Feb 6, 2021 01:12 PM
Jag7
XE ( X760 )
May 11, 2018 02:31 PM
AdrumQc
XE ( X760 )
May 10, 2018 02:40 PM
Klemen Ošlaj
XE ( X760 )
Sep 22, 2015 07:42 AM
