XE ( X760 ) 2015 -
Airbag light
Old Jan 2, 2018 | 06:16 PM
Jamie Foster's Avatar
Question Airbag light
Currently working on a 2017 XE 3.0 AWD rebuild that was in a wreck- planning on upgrading my wife to it
Replaced driver bag, clockspring, driver curtain, had all belt pretensioners rebuilt and control module reprogrammed and all reinstalled
Still throwing a permanent code- B1193-68 Crash event storage full and locked
At first I figured the module must of not been reset correctly but after contacting them they said this code pertains to the occupant sensor and that is needs reprogrammed.
My maxisys ds708 wont show any hot functions for this new of car so unable to try that.
I have rebuilt quite a few xf airbag systems and never had any issues with any occupancy sensors, is it a new type of sensor in the 2017 that stores crash data? and idea?
Sensor still working fine and occupancy light turns on and off like it should.
Suggestions?
Old Jan 3, 2018 | 01:18 PM
JLR website gives the following information for 2017 XE regarding Event Data Recording in crash situations:
Jaguar Owner Information
Even if you clear the B1193-68 DTC, I'd expect the associated data to be retained unless it is retrieved or cleared with Jaguar SDD. Until this is done, the DTC will just reset because the full storage and lock conditions still apply.
My 2015MY XK has the same system. SDD doesn't show any separate EDR under modules so I presume the data is stored in the RCM.
JimC64
Sep 22, 2025 02:52 PM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
Drossvet
Oct 21, 2016 09:27 AM
Jeff DeVere
Oct 13, 2016 07:00 AM
