XE ( X760 ) 2015 -
Jaguar XE 2015 petrol P2635-7b
Old Jan 2, 2025 | 08:53 PM
Sundaram03's Avatar
Default Jaguar XE 2015 petrol P2635-7b
Having issue with my car since October and have been to the workshop 7 times and spent alot to get this rectified
ECM displays the following error codes
P2635-7b Fuel Pump A Low flow/performance Intermittent
P008A-07 Low pressure fuel System Pressure is too low Pending
P0496-00 Evaporative emission system high purge flow Intermittent
P0497-00 Evaporative emission system low purge flow Historic.
Have
replace all this parts, but the problem persists
engine valve cover assembly Engine camshaft Solenoid Exhaust Engine Camshaft Solenoid Intake Engine camshaft sensor Exhaust Engine camshaft sensor intake High pressure fuel pump Low pressure fuel sensor Exhaust Catalytic converter charcoal canister fuel feed pipe and Purge valve Turbo Intercooler Intercooler Intake Manifold Hose Intercooler outlet hose Spark Plug Fuel Pump Fuel Tank Pump O-ring Fuel tank Pump.
Can the expert provide some advice.
Old Jan 3, 2025 | 03:19 AM
Robtrt8's Avatar
Which engine? L4 or V6?
Has it been to the dealer?
Old Jan 3, 2025 | 09:19 AM
DJS's Avatar
DJS
Does your car still have the original battery? A weak battery can trigger all sorts of codes.
Old Jan 6, 2025 | 07:27 PM
Sundaram03's Avatar
V6, Sent to well known workshop for diagnostics and repair
Sundaram03's Avatar
changed to an oem battery last year august, battery is still good
Old Jan 6, 2025 | 07:28 PM
Sundaram03's Avatar
Can anyone tell me when the fuel control module is located in this car
SNAPCHAT
Apr 15, 2026 11:16 AM
Tavita05
Mar 27, 2024 09:38 PM
Jeff Johns
Mar 17, 2024 07:14 PM
bscho
General Tech Help
May 18, 2019 11:01 PM
FastKat
Dec 24, 2012 07:43 PM
