XE ( X760 ) 2015 -
Multiple lights? Any previous experience
Old Oct 1, 2024 | 01:58 PM
Ryman's Avatar
Default Multiple lights? Any previous experience
Evening all,
seems everything has popped up at once!
Abs faultAeb not available
Forward alert not available
Emergency break assist not available
Stability control not available
has anyone experience this before and know where to start before heading to jag for the £200 diagnostic
thank you
Old Oct 1, 2024 | 03:12 PM
DJS's Avatar
DJS
Jags are quite sensitive to battery voltage. Try putting your battery on a charger.
Old Oct 1, 2024 | 04:11 PM
Robtrt8's Avatar
If the battery is more than a couple years old I’d plan on buying a new one. New batteries are 1,000 amps and the car starts to go nuts below 600 amps. Make sure the battery tester and the battery charger are OK for AGM.
Old Oct 3, 2024 | 04:56 PM
dangoesfast's Avatar
Those codes together make it sound like the car either can't "see" what's in front of it (so possibly a camera/radar issue, or an issue interpreting the data) or there is something stopping the car from taking emergency action (brake or ABS issue, sensor issue, etc). I think you can get a similar set of errors if one of your tyre pressures is low enough since the car will disable a lot of its autonomous systems until the pressure is back in range.
It could also be something COMPLETELY unrelated that affects one of these systems, like a low battery as already suggested. I remember my car throwing a similar collection of errors once before and they disappeared after a restart, still don't know what caused it 🤷
Old Oct 3, 2024 | 06:24 PM
Fraser Mitchell's Avatar
It could just be a wheel sensor. These are not usually expensive, and a scan of the faults will tell you if one has failed and which one it is, (four = one per wheel)
Old Oct 11, 2024 | 12:15 PM
TerrysXE's Avatar
I have exactly the same on my XE. Traced to water ingress to power steering motor. Whole new steering rack required, thank heavens for eBay and refurbished parts. I will let you know if the answer etc lights go out after fitting new rack.
Old Oct 11, 2024 | 01:06 PM
Ryman's Avatar
im hoping to buy an obd 2. Clear it and it won’t come back 😂 keep me posted please
Boeingtravel95
Apr 16, 2014 07:37 AM
Kevinhj
Aug 25, 2013 09:42 PM
smgdata
Mar 9, 2013 08:38 AM
Badia358
May 12, 2011 12:07 PM
FrankF
May 24, 2009 05:54 PM
