XE ( X760 ) 2015 -
Silence after shut down
Old Dec 11, 2018 | 03:37 PM
pajeff02's Avatar
Default Silence after shut down
One thing I noticed right away about our XE was that after shutting off the engine I could hear a small pump running. Presumably, the pump is circulating either oil or coolant to the turbo - never checked to see what it does. I realized the other day after shutting the car off that I did not hear the pump running. I checked again a couple of times and, even after longer trips, still no pump noise emanating from under the hood. Our weather is now much cooler in PA, so not sure if the after cooler function is connected to outside air temp or what the scoop is. Anyone?
Old Dec 11, 2018 | 06:48 PM
keith100's Avatar
My 35T hums quietly to its self, as did my previous MB, for about 10 mins after shutdown. (The dealer said its 10 mins+-, I never waited to find out) It's the cooling fan for the computer/infotainment system. I don't recall it being affected by the outside temperature though.
Old Dec 12, 2018 | 05:58 AM
pajeff02's Avatar
Thank you for the reply, but I am fairly certain that this noise is an electric pump running under the hood and not in the dash. I do hear a low hum from the dash area and that must be the fan for the electronics.
Old Dec 14, 2018 | 09:51 AM
zach05855's Avatar
I think what you are hearing is the electric fan for the radiator, which is controlled by a thermostat.
Old Dec 14, 2018 | 07:45 PM
pajeff02's Avatar
Hmm. Easy enough to check that, but the noise is a low and steady drone rather than the whir of a fan.
Old Dec 19, 2018 | 05:56 AM
pajeff02's Avatar
Our temperatures came up a bit in our region and the noise of a pump running has now returned upon shutdown.
Brewtech
Apr 21, 2024 01:27 PM
GrahamPhotog
Nov 10, 2015 01:29 AM
Enzo954
Mar 18, 2015 05:13 AM
sar98vdp
Jun 20, 2012 04:17 AM
marco_hevia
Sep 9, 2011 08:02 AM
