XE ( X760 ) 2015 -
VelocityAP Jaguar XE Exhaust System Development
Old Jun 22, 2017 | 12:20 PM
Stuart@VelocityAP's Avatar
Sponsor
Originally Posted by OzXFR
The current XF (X260) has a different rear mufflers and pipes set-up to the earlier XF (X250). The X260 mufflers and pipes are much closer to the centre of the rear end, so an exhaust set-up made for the X250 will not come even close to fitting an X260.
Okay, gotcha. So we will need an original pattern to work from to develop that part.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Jul 10, 2017 | 11:38 AM
Sponsor
View this post on Instagram
Anyone want their XE to sound like this LOL?
FYI this is 200 cell sport cats with our loudest (Supersport) exhaust, pulley + tune. Obviously this isn't the right sound level for everyone, it's damn loud.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Jul 10, 2017 | 12:44 PM
Demetre Gvaramia's Avatar
Originally Posted by Stuart@VelocityAP
https://www.instagram.com/p/BWQq8Qyg...iveperformance
It sounds great!
I don't mind my exhaust being loud. What matters the most is at what engine speed does it make that sound.
Quiet on low revs and loud at high revs would be perfect for XE.
Old Jul 10, 2017 | 01:40 PM
Sponsor
Originally Posted by Demetre Gvaramia
It sounds great!
There's no magic stuff that can make it louder at one RPM than another, other than the fact that wider throttle openings & higher RPM are generally louder than the converse.
V6 engines can be drony, and the louder you go the more drone you get. On this car, when I'm driving it I like to use the paddles so I can avoid the RPM range (around 2000) where the drone occurs.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Jul 12, 2017 | 07:14 PM
Shagman25's Avatar
Being able to select the exhaust note on a XE S with the same 280HP engine as the F-type would be great. Sign me up if this ever becomes an option. I would surely put this system through a battery of tests. This is the one thing I miss so much from the XE versus the F-Type. IMO a marketing loss for JAG. Everyone in the states is altering the exhaust note of their car to sound more powerful and exciting. The F-Type just nails it!!
They could have added this as an option for $1000 and I, and others would have added this to our build. Just amazing.
To create a soundtrack like that and not offer that on other vehicles is just a marketing oops.
Old Jul 12, 2017 | 10:02 PM
chariot44's Avatar
If this exhaust comes with a valve system, like the Ftype or some other exhaust manufacturers, it will make it more attractive for owners not wanting loud all the time, especially around coppers.
Old Jul 13, 2017 | 11:33 PM
Sponsor
Okay guys & gals. I've been staring at a bunch of pictures, and I have come to the conclusion that the XE and the FPace have the same exhaust fitment. Or at least I'm 99% sure.
Which means the FPace system we already developed should fit these cars nicely. And it will be possible to set it up as a valved system.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Jul 29, 2017 | 03:35 PM
  #28
alphakinase's Avatar
That's good news. Any comments on how your FPace/XE setup differs from the one you offer for the F-type? Many of us would hope to get as close to the F-type sound as possible with the XE, maybe not as crazy as that instagram video above in terms of volume but the tone was spot on.
Old Jul 30, 2017 | 08:28 AM
mosesbotbol's Avatar
The F Type has that additional fuel being added off throttle to get the popping which is not done on the XE. Can that be altered in the ECU?
Old Jul 30, 2017 | 03:47 PM
  #30
This is what I think the XE should sound like... and I know it's fully capable
If you check out the video Stuart posted of that F-Pace with their sport exhaust, you can hear it crackle and pop, but it's muted compared to the above F-type video. Since both that F-Pace and this F-type were tuned with the VAP software, I think the difference in crackle/pop volume comes from the exhaust setup, not ECU. The F-type has 200 cell cats as well.
My preferred setup would probably be: 200 cell cats, drone-canceling mufflers with minimum volume attenuation, no center resonators, and a valve to keep things in check for the wife/long drives.
Old Jul 31, 2017 | 10:22 AM
  #31
Sponsor
The FPace/XE exhaust, from the center section back bears no resemblance to the F-Type. On the FType there is a single transverse rear muffler, chambered and on the Active option valved as well.
The FPace has two separated rear mufflers.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Jul 31, 2017 | 12:13 PM
  #32
Thanks. I understand the stock setups are quite different. My question was aimed at understanding how the VelocityAP aftermarket setups for both vehicles differ. So are the VAP dual rear mufflers for the XE similar in design to the VAP F-type single muffler (apart from being split), and would they yield a similar tone?
Old Jul 31, 2017 | 12:33 PM
  #33
Sponsor
Yes, they are split design. There's no room or mounting points to attach a transverse rear muffler to the XE/FPace. Ordinarily there's a sound difference between split and XPipe variants, except with the center resonator on the V6 cars they are already merging flow to a large degree so I wouldn't expect that much of a sound difference.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Aug 1, 2017 | 08:48 AM
  #34
BigCat09's Avatar
I can tell you all that my XE and my FPace both sound much different stock. The Fpace is so much louder maybe because it is an open cabin. Maybe I have to lower the rear seats in my XE to get the same volume into the cabin?
Old Aug 1, 2017 | 08:55 AM
  #35
I can confirm this. Had an FPace S loaner for about 2 weeks, and immediately noticed it was about 50% louder in the cabin. I could have sworn it was coming from the speakers, but I don't think JLR does that. Outside it sounded about the same as the XE though. Granted, it was the 380 bhp tuned engine so that could account for a bit of added volume.
Old Aug 1, 2017 | 10:38 AM
  #36
I believe there is a tube that directs some engine sound into the cabin, not a speaker like BMW does.
Old Sep 11, 2017 | 02:25 PM
  #37
drdonger's Avatar
Hi All, I'm a newbie to this forum. I recently started reading this thread because I am planning on installing an exhaust on my RR Sport HST v6. I noticed that the F type v6s and the F pace v6s do not have the secondary resonator as some have shown, while the RR v6 and XE do. I'm planning on deleting the resonator and keeping the front and rear mufflers this Wed. I will post a vid when I'm done. If it still doesn't sound good enough, I will swap the mufflers, right now will give the resonator delete a try.
Old Sep 13, 2017 | 04:09 PM
  #38
drdonger's Avatar
Here is the video of the resonator delete on my RR Sport V6. I kept the center muffler before the resonator and rear mufflers.
Old Sep 13, 2017 | 09:28 PM
  #39
drdonger's Avatar
Old Sep 13, 2017 | 10:36 PM
  #40
steel12's Avatar
I have been testing tunes for Chris from VAP.
Something very exciting happening when it comes to sounds
