XE ( X760 ) 2015 -
XE v6 r sport odd engine noise
Old Apr 14, 2024 | 11:32 AM
Ryan48's Avatar
Default XE v6 r sport odd engine noise
Hello. After using the incontrol app to start my car for the first time via that method, I heard a 'clunk' sound 10 seconds after shutting the car off. I would equate it to the sound/loudness of the hood latching. I have not noted this before. Does anyone have any insight? Thanks!
Old Apr 14, 2024 | 11:37 AM
Mazen Ajouz's Avatar
I do hear that type of noise occasionally after shutting down the car since I bought it brand new, not sure what's its source or whether it's a cause of concern.
Old Apr 14, 2024 | 12:01 PM
Ryan48's Avatar
It seems to be 4-5 seconds after shutting the car off. Oddly it started the first time I used the incontrol app to start it. I am unsure if it is the fuel position valve or dreaded sc coupler issue. The sc issue however would make the noise at shutoff, not afterwards, correct? The reason I am nervous is I have only put 500 miles on it since buying it used. My initial impression was it ran great, but imo a little rattle-y at idle. Do you happen to know if the SC coupler clunk sound is present.immediately at shutoff, or if it is delayed as well?
Old Apr 14, 2024 | 12:11 PM
The Jaguar AJ126 engine is not known for its refinement or quiet operation, read the following long-term test of the XE where they complain about the random drivetrain noises:
2017 Jaguar XE 40,000-Mile Long-Term Test (caranddriver.com)
Old Apr 14, 2024 | 12:19 PM
Ryan48's Avatar
Thanks. That article sums things up well. I have not had issue with thd 20" tires or wheels, and out streets are the worst in the state. I now know to be extra careful though.
Old Apr 14, 2024 | 04:14 PM
DJS's Avatar
DJS
Yes, the clunk from a bad SC coupler comes as the engine stops turning, not after.
Old Sep 10, 2025 | 08:20 AM
Haalex's Avatar
I know this is old, but the noise you're mentioning (a sort of thud) is the throttle calibrating itself. Perfectly normal.
A bad coupler can be heard as the engine is shutting off and sounds sharper.
Old Sep 11, 2025 | 06:58 AM
walkerwilson4's Avatar
Lightbulb
That clunk is usually nothing to worry about. After shutdown, a few systems on these cars cycle or reset. Common ones are:
  • EVAP purge valve / fuel system – it can vent or depressurize a few seconds after shutdown.
  • HVAC blend doors – sometimes you’ll hear a thump as they return to their default position.
  • Electronic parking brake or relays – these can make a mechanical “clunk” that sounds like a latch.
It tends to be more noticeable when shutting the car down remotely since you’re outside and listening for it, rather than just walking away after driving. If the sound is a single, quick clunk and there are no warning lights or repeated noises, it’s considered normal behavior. If it changes in volume/frequency or is accompanied by other symptoms, then I’d have the dealer check it out.
Manuel1234
Jan 4, 2024 06:27 PM
marcosmaniac
XE ( X760 )
Nov 17, 2022 07:34 PM
Cincy XE-RS
XE ( X760 )
Dec 17, 2018 12:09 PM
NewLester de Rocin
XE ( X760 )
Jun 27, 2017 02:51 PM
whoisbigman
XE ( X760 )
May 1, 2017 08:25 PM
