XF (X260) 2015 onwards
cigarette lighter socket
Old Dec 29, 2025 | 03:50 PM
Tomek_krot's Avatar
Default cigarette lighter socket
Hi,I'd like to install a cigarette lighter socket near the gear shift in my 2018 X260.I already have the original socket.Are there already power cables there, or do I need to run new ones?
Old Dec 30, 2025 | 01:31 AM
RoverJoe's Avatar
Community Influencer
There are usually not extra plugs on the harnesses as they are built per VIN to the spec of the car. You will most likely have to add the wiring you need for the power outlets, but open it up and see, maybe that was something they left in all the cars.
If you need OEM connector info I will try to help out with it as much as I can.
Old Dec 30, 2025 | 08:58 AM
2018XF25T's Avatar
Just keep it simple and easy to remove. I would not recommend this if you'll insert a cigarette lighter as it might blow fuse/fuses or possibly cause a fire in the car
Amazon Amazon
mattyhurd
Nov 6, 2021 06:38 PM
SteveSheldon
Dec 20, 2016 10:04 PM
ronrowand
Aug 21, 2014 04:45 AM
Fairlane500
Aug 27, 2011 09:52 PM
jonbugh
Oct 21, 2008 04:11 PM
