XF (X260) 2015 onwards
Engine light on
Old Mar 8, 2018 | 01:39 PM
jaglover48's Avatar
Default Engine light on
Will the flap on the neck of gas tank, where the gas pump is inserted, cause engine light to come on , when flap is stuck open?
Old Mar 8, 2018 | 03:07 PM
alspal's Avatar
Yes, I had exactly the same issue a couple of weeks ago.
I simply unscrewed the petrol/gas filler gap and then put it back on making sure I tightened it sufficiently until I'd heard a couple of "clicks"
I don't fully understand why but I believe that if there is any sort of back pressure or vacuum caused by a loose or untightened gas/petrol filer cap, it does cause the engine light to come on.
I was very relieved that that was all I had wrong with mine!
Hope this helps
Good luck
Old Mar 8, 2018 | 03:14 PM
alspal's Avatar
Sorry Jaglover48, I just re-read your post and you're talking about the fuel filler flap, not the actual fuel cap. In that case I don't know but worth checking the fuel cap is tight just in case. Possibly a flap which is stuck open could cause issues in the fuel tank when you're at speed but only if the fuel cap was not sealing properly.
Old Mar 8, 2018 | 03:34 PM
If the engine light on there will be a code set.
Take it to Autozone or somewhere similar and have them check, there is no point guessing.
Old Mar 8, 2018 | 03:50 PM
mleskovar's Avatar
Shouldn't, but why is it stuck open? If it's because the filler cap isn't seated properly and protruding/preventing the flap from closing then yes.
Old Mar 8, 2018 | 06:45 PM
Welcome to the forum jaglover48,
What vehicle are we discussing here? You've made 2 posts in X250 forum and now this one in X260 forum.
The photo is my XK but the arrangment is similar. If the Fuel Filler Flap (arrowed in red) is open, it will show a warning but not trigger an error code.
If the Fuel Filler Cap (arrowed in blue) is not on tight it can cause the MIL to illuminate but there are also many other reasons why it illuminates.
innzane
Apr 3, 2016 08:43 PM
prince_kuja
XJ XJ12 ( X305 )
Feb 18, 2015 12:32 AM
hotel_gm54
22
May 15, 2013 02:41 PM
jsmolin
XJ40 ( XJ81 )
Jan 11, 2011 09:14 AM
