Oil level
Hi, I use the info in my manual on how to check the oil level but on the screen I get check your users manual.
I'm told to warm up the car then without starting it push the button until I get to the oil level, that's the problem, it says not avaiable
and to see the manual.
Could this be a sign of a bad sensor?
2015 XF Sportbrake
Many thanks,
2015 XF Sportbrake
Many thanks,
I tried it when the engine was cold and did get the oil level to show.
It was about 50%, after a drive I checked again after waiting and it said I should
add 1/2 a liter, guess the second reading is more accurate.
Thanks again for your suggestions.
My guess is that it's more accurate when cold because all the oil has been drained to the sump. I used oil for the first time between changes on my last one at 18K miles. It was down 3/4 way on the meter when cold. When I warmed it up and checked it went up to 1/2 way and I attributed that to the oil expanding when warm. I also attributed the usage to almost all my trips between changes were short, around town, and on a cold motor with no long trips on the 0W-20. Lightest recommended oil for any car I've had.
dvsadam
Sep 21, 2011 02:54 PM
