XF (X260) 2015 onwards
Parking sensors
Old Apr 5, 2018 | 11:05 AM
ben30's Avatar
Default Parking sensors
Hey, when I reverse and there is a car in front of me they parking aid beeps furiously and correctly shows that in front of me is a block, but why does this happened when I have reverse in gear and nothing is behind me? It's fairly annoying leaving a garage reversing when the parking aid beeps multiple times even though nothing is in the way of the reverse. Is there a setting for this, or can I just turn the whole thing off completely?
Old Apr 5, 2018 | 03:40 PM
JBzXJ40's Avatar
If you have park aid front and rear, it's supposed to do that. Its going to tell you whether your in reverse or in drive ( below certain speed ) if anything is around the vehicle. If there is nothing in front of the vehicle, but is showing that something is, then you may have a faulty sensor.
Usually on the new XF - you will get a message on the touch screen that says camera unavailable, please see your dealer.
Old Apr 5, 2018 | 04:37 PM
ben30's Avatar
I just figured if I select reverse it wouldnt be necessary to warn me there is something in front of me, unless I select drive to go froward
Old Apr 5, 2018 | 07:31 PM
BritCars's Avatar
You still need the front ones when you're in reverse as if you're turning then the front corner can still hit something while you reverse.
So they are all on at the same time to avoid any mistakes!
Old Apr 7, 2018 | 07:37 PM
mleskovar's Avatar
Correct! If you just drive up to an obstacle Parking Assist will not activate unless you select it with the button. Parking assist forward automatically engages if you go from R to D.
Cockbain
General Tech Help
Jul 17, 2015 09:22 AM
Red October
Feb 9, 2015 06:32 AM
Stevil
Jan 19, 2009 03:55 PM
bubbawing
Oct 22, 2008 01:17 PM
X2 Jag
Jan 1, 2007 07:50 PM
