XF (X260) 2015 onwards
Swapped Headrests?
Old Nov 19, 2021 | 03:02 PM
MeatBag's Avatar
Default Swapped Headrests?
I recently bought a Certified 2018 XF S from the nearby Jag dealer.
It had the same full-size headrests on the two outboard rear seats as it had on the front seats.
They blocked the view out the rear so badly that I decided I had to remove them.
They were so tall I almost couldn't get them out for lack of clearance.
The middle seating position has a nice short headrest - and I thought "get two more of those".
Then I saw other XFs where all three rear seats have the short headrests, like these...
Low profile rear headrests
I had the tall ones from the front in the two rear outboard seats as well.
Was this an option of some sort? Or maybe someone swapped them for some reason?
Tx
Old Nov 19, 2021 | 03:35 PM
mleskovar's Avatar
Tx
There's a button on the side of them you push and they flop down...............
Old Nov 22, 2021 | 02:13 AM
pk4144's Avatar
On my XF Sportbrake it's the same thing-- the center rear headrest is entirely different from the other four, and is similar to the three rear headrests pictured. And the two larger headrests absolutely block visibility. And while yes, there's an obvious button to fold the larger ones forward, they are far more obtrusive than the center headrest even when folded forward, which I believe is the OP's issue, and I agree.
I've never seen the three small headrests.
FYI, here's a single one (in "Oyster") on Ebay to give you an idea of price.
(Other option, which I'm going to do, is simply keep the larger ones in the back and put them back in if you have need of them.)
https://www.ebay.com/itm/143894696311
Old Nov 24, 2021 | 05:05 PM
Stephen.513's Avatar
North American spec cars have the big headrests, EU spec cars have the smaller ones as pictured. Not sure why.
Old Nov 25, 2021 | 11:20 AM
MeatBag's Avatar
Maybe its because North Americans have big heads...
Spikepaga
Jul 26, 2019 12:23 AM
sfdoddsy
Sep 17, 2017 07:54 AM
scarbro2011
Dec 8, 2015 06:17 AM
rama1200
Apr 5, 2011 06:38 PM
IrishXtype
Aug 27, 2010 02:36 PM
