09 XF Supercharged Custom Intake
Old Aug 19, 2013 | 06:56 AM
Blackcoog's Avatar
Default 09 XF Supercharged Custom Intake
I fabbed up a custom intake tubing kit for my XF. It replaces the plastic resonated section and the accordion tubes. So far I'm very happy with it. It's hard to say much about hp gain unless I had dyno numbers. I was mainly looking for more sound. I haven't reset the battery yet. Sound has increased a bit but it isn't significant. I'll report back after a battery reset and some miles.
Old Aug 19, 2013 | 06:09 PM
chXFS's Avatar
I want one!! Can you reproduce?
Old Aug 20, 2013 | 07:54 AM
Blackcoog's Avatar
I can definitely reproduce this for others. There isn't much out there for the XF so every little bit helps. Drop me a PM if you want one and I can get your more details.
See the link in my sig to buy your own intake.
Old Aug 21, 2013 | 08:31 AM
Doryphoros86's Avatar
Looks very nice! I will have to keep this in mind when I upgrade from the STR to an XFR. Great to see an another person from Minneapolis area on the forum!
Old Aug 21, 2013 | 10:01 AM
swaite3's Avatar
What size tubing did you use?
Old Aug 21, 2013 | 10:59 AM
Blackcoog's Avatar
I used 3" tubing which is slightly larger than the stock size. Anything larger will have issues with hood clearance.
Old Aug 21, 2013 | 11:26 AM
swaite3's Avatar
very nice, I like the set up, how much louder is it than stock?
Old Aug 21, 2013 | 02:56 PM
Executive's Avatar
XFR has the 5 liter engine, slightly different configuration. Don't think it would make a difference on 510hp engine anyway.
Old Aug 23, 2013 | 09:26 AM
Blackcoog's Avatar
The sound increase is noticeable but it isn't excessive. It isn't as loud as these videos of a XJ 4.2 SC with a intake pipe. I'm not sure why. The videos are still interesting though:
VIDEO0003_zpsac5665bf.mp4 Video by caldoofy | Photobucket
VIDEO0035_zps5765bf6b.mp4 Video by caldoofy | Photobucket
Picture of the XJ 4.2L SC with the single intake tube:
Old Aug 23, 2013 | 10:22 AM
Doh, that's right . Even says right in the title that it is for an 09. Regardless, it is awesome that someone made a tube for the 09 guys' 4.2 motors!
Old Aug 23, 2013 | 10:37 AM
Blackcoog's Avatar
If there is someone local to me (Minneapolis) with a SC 5.0L/XFR they could bring it to me and I could put something similar together.
Old Jun 4, 2016 | 02:13 AM
Jav's Avatar
Jav
Default Hi Mate that's looks awesome can you make custom orders
Looks fantastic can you make me one?
Old Aug 8, 2016 | 11:34 PM
zerotrigun's Avatar
Default I would like to purchase one
Do you still make these?
Old Aug 9, 2016 | 06:16 AM
Blackcoog's Avatar
Go here: Twin Cities Performance|Performance Parts|Minneapolis Minnesota
Old Aug 11, 2016 | 08:52 PM
rlentini's Avatar
Just installed mine today. Didn't take long. Hoping I have no leaks and all good seals. Any easy way to check for leaks? Loosening the filter covers is basically required. Excited to drive around tomorrow. I didn't trim the engine cover. Will look at it again and see if it seems necessary another day. Definitely looks good.
Old Aug 12, 2016 | 06:40 AM
Blackcoog's Avatar
Good deal! You'll know right away if you have a leak. You'd get a check engine light or erratic idle. The cover doesn't need to be trimmed but it helps it fit better.
Old Jan 26, 2020 | 03:57 PM
fivel's Avatar
Do you know if anyone is still making these intakes for the 4.2 SC?
Old Mar 15, 2020 | 12:51 AM
xGrayBushx's Avatar
What's the degree of the angle on that y pipe?
Old Mar 16, 2020 | 09:22 PM
rlentini's Avatar
I measure 135 degrees, measuring base of left intake and bottom right of rubber angling into center. Geez, my explanation probably just confused things. Let me try again. I get 135 degrees on the outside arms coming into the middle. If you mean the angle between the two arms as they enter the center, I'll have to remeasure, as I'm not sure the arms are at 180 degrees from each other.
Old May 29, 2020 | 09:27 AM
Nigelschiess's Avatar
Default Any way I can buy a custom piece? Or could you tell me specs of the custom piece?
my plastic y pipe air intake cracked and I can’t seem to find a NEW replacement so I either want to make a custom or buy one!
