2010 3.0D XF seized back brake
The drivers side (right-hand drive) brake caliper is sticking. The calipers, pads and discs are only brand new and we're only installed a few days ago.
However when I realise and pulled over the disc was pretty hot and was smoking so I am not sure if I have ruined the disc and caliper!!
Considering the discs and calipers are only new I'm guessing it's an issue with the handbrake cable, is this a known issue and destroy a way of disconnecting the handbrake cable or just not using the handbrake.
Theyfreed out after a few minutes and I managed to drive the car home so it's an intermittent problem which may end up being a stuck caliper rather than the handbrake!!
It's an automatic so at least I can leave it in park
