2010 XF petrol 3.0 P171 and P174 issue
Old Apr 14, 2019 | 12:26 PM
hoylegj's Avatar
Default 2010 XF petrol 3.0 P171 and P174 issue
For the last few months I’ve had both codes, so the time has come to resolve it, so far no joy, what have I done so far, the car also has a poor idle and has got worse from year one. No other error codes. Jaguar looked at the car 3 times over the years to find the poor idea and failed. It’s now at the point it needs fixing.
changed the maf
checked for vacuum leak, used smoke and pressure No leaks detacted
striped the manifold off and replaces the O rings around the pvc vacuum pipes
all cleaned and reassembled
cleared faults, disconnected he battery, after five mins both codes back
the car runs on LPG and petrol, I get the fault on both fuels, it runs 5% petrol while on gas.
Smoke tested again, nothing,
ok, main fold off again and bit the bullet and removed the Lower manifold as well, it’s very messy, but the seals are good.
All ideas welcome, still in a thousand pieces, so anything else to check.
Thankyou for looking.
Geoff
smoke pot worked well..
Smoke can
Old Apr 14, 2019 | 05:36 PM
Gus's Avatar
Gus
I have used throttle body cleaned and with the engine running spray around the manifold and all vacuum hoses until the engine starts to stumble. It is a little time consuming but effective. On the 3.0 several people had problems with the “O” rings on the manifold using this method should help. Be sure to get a few cans you may need them.
Old Apr 24, 2019 | 04:48 PM
hoylegj's Avatar
Here is a video of the odb readings , it’s long but riveting not
Old Apr 24, 2019 | 09:32 PM
Gus's Avatar
Gus
A P0171 & P0174 can be caused by many things mainly related to the mix of fuel and air. If you are without any vacuum leaks that you can find I would be looking at your injectors. If you can use petrel then add a fuel additive or pull the fuel injectors and have them tested and cleaned. I use BG44K the best I found on the market.
Old Apr 24, 2019 | 10:08 PM
litteredwithfaults's Avatar
The leak can also be on the exhaust side, any air escaping between the exhaust valve and O2 sensor.
Old Apr 27, 2019 | 12:53 PM
hoylegj's Avatar
Thanks litteredwithfaults I’ve just disconnected the secondary air pipe from the blower and blocked it, STFTs are now much more stable and the idle is so much better. Ecu reset next, , so secondary air valve is now a possibly, more testing to follow
thanks
Old Jul 31, 2019 | 08:50 PM
PJ704's Avatar
I have the same error codes P0174 and P0171 on my 2010 XF. Not sure what it is exactly but I did notice a crack in my air intake tube. Would this be the culprit?
Old Aug 2, 2019 | 07:04 AM
JagV8's Avatar
Probably. The whole air intake set of parts must be 100% sealed vacuum tight.
Old Apr 26, 2026 | 11:03 AM
gretle_2.0's Avatar
Ever figure out the issue?
Old Apr 27, 2026 | 07:42 AM
hoylegj's Avatar
in my case it was lpg issue, the lpg injectors were leaking and thus the mixture was all over the place. generally a air leak, or fuel flow, could i guess be a injector simliar to my lpg issue
good luck
Old May 6, 2026 | 10:05 PM
Isaac's Avatar
Check your fuel pump. Fpr sounds like your chasing all my previous gremlins but went much deeper then I did to start. Also pcv replace that as well.
hoylegj
Jan 17, 2019 06:32 PM
mrsambem
19
Apr 22, 2014 02:40 PM
Jimmy Z
Sep 25, 2013 08:00 PM
RedJagX
Nov 12, 2011 07:58 PM
Brian2000XKR
Jul 31, 2010 02:14 PM
