2012 XF drivers side seat
Old Jan 15, 2018 | 12:49 PM
ddigesu's Avatar
Default 2012 XF drivers side seat
The drivers side seat on my 2012 XF will not adjust. None of the buttons are working except for the lumbar pressure. I have tried changing the fuses but that does not fix the issue. Any suggestions? thanks!
Old Jan 15, 2018 | 03:34 PM
JBzXJ40's Avatar
Do you move the seat position often? Sometimes sitting in the same position for so long can cause the motors to get stuck.
You mentioned changing fuses - did you check the correct ones? See attachment of wiring diagram. Fuses are located in Central Junction Box.
Have seen a few switch packs go faulty - but not often.
What happens if you press memory switches?
Attached Thumbnails 2012 XF drivers side seat-2011xfcentraljunctionbox.png   2012 XF drivers side seat-2011xfdriversseat.png
Old Jan 18, 2018 | 02:54 PM
ddigesu's Avatar
Default Thanks for the reply
I did change the correct fuses. The memory buttons are not working either. The seat doesn't get moved often but every couple of weeks my Son drives the car & he moves the seat.
Old Mar 9, 2018 | 09:36 AM
jahmezis45's Avatar
Did you find a fix for your seats? I am having the same issue right now
Old Mar 1, 2021 | 07:44 AM
jonah1uk's Avatar
Default Drivers Seat Fix XF X250
I've just had my drivers seat fixed as it had lost all button controls to adjust it including the door memory options. After several hours with my local jag specialist the fault was identified as the seat control unit. So replacement unit in and we were up and running. Final cost £490.00 + VAT. I love Jag repair bills they make my day....
nasa25
Mar 20, 2015 07:43 AM
DonsXJ8
Oct 17, 2014 11:43 AM
barondess
Apr 16, 2014 07:18 PM
zathras
Dec 19, 2013 05:44 PM
SRL1990
Apr 26, 2010 11:47 PM
