2012 XF Pad\Rotor options?
Old Nov 19, 2014 | 11:09 AM
Wadess's Avatar
Default 2012 XF Pad\Rotor options?
I'm getting the low brake pad message and the dealership says I need new pads and rotors all around. The car has 46k miles so I don't doubt it. My experience with my previous cars has been that you can get better alternatives for the price of OEM or equivalent alternatives for cheaper. Is that the case with the XF (Portfolio)? What are your experiences, good or bad? Any recommendations?
Old Nov 19, 2014 | 11:13 AM
texsn95's Avatar
How did they determine that you need new rotors? Did they measure the rotor thickness and compare it to minimum thickness spec? Doubt it. Dealerships aren't called "***********s" for no reason 46k is not that many miles on rotors.
R1 Concepts have a large following and I've used them in the past for M45 rotors with no issues.
Edit: $tealerships is blocked, ha!
Old Nov 19, 2014 | 09:47 PM
lotusespritse's Avatar
46k miles is a lot for these brakes and rotors. The stock pads eat the rotors.
Old Nov 20, 2014 | 08:29 AM
Brutal's Avatar
and would you want to help people that called you a thief.
Said nothing about attorneys, politicians, or even dentists that charge $500 for teeth whitening that cost them $50.
Old Nov 21, 2014 | 12:36 AM
bollocsk187's Avatar
Check my post on this area it is an interesting one:
https://www.jaguarforums.com/forum/x...rching-130518/
Net is I would agree with the dealer - new Brakes new Rotors. My car had 48K. It should cost you around $2K. If you can do it yourself then you will safe money :-).
H20boy
Dec 24, 2024 03:23 PM
danke
Mar 3, 2016 10:57 AM
wannajag
Sep 22, 2015 08:29 PM
handcuffsready
Sep 7, 2015 01:02 PM
JagLove86
Sep 6, 2015 10:36 PM
