2012 XF phone voice commands
Old Nov 3, 2012 | 08:13 AM
oakcircle's Avatar
Default 2012 XF phone voice commands
Last weekend, I purchased a 2012 XF and love it. However, I am having trouble figuring out how to use the voice activation to dial a number without having to give the system 5 commands. I've added voice tags to the numbers I dial most, but it doesn't seem to expedite the process. Any suggestions/command sequences that would shorten this process would be greatly appreciated.
One other minor frustration is that in the navigation system, there seem to be inconsistent POI info. I can approach an exit in a rural area, and there will be several POIs listed. I can later approach a major exit with many, many POIs, but none appear on the screen. I see there has been a post this morning concerning uploading of POI info. I'll be anxious to see the responses to it.
Old Nov 4, 2012 | 01:57 AM
Globot1's Avatar
I have recently also purched an XF and had the same problem with the voice comand and i think that is the only way to use it via going through 5 comands. actually twice i said "Call Bob" and it automatically called that certain number.
But it is still a slow process while using the voice comand to confirm each of your comands. I wish there was a way to shut it off and directly call someone like in my ML550
Old Nov 4, 2012 | 06:59 AM
jjsaustin's Avatar
For the phone, you don't have to say "phone", just press the button and say "dial voice tag", then "home", then confirm. So it is 3 steps.
You can also press the voice button when or is speaking the "Confirm yes or no" message and say "yes". It eel safe you a few second and you dont have to listen to the whole confirmation message.
For the radio, you can combine the first two steps and say "radio tune frequency", but I don't think you can say "radio tune voice tag" with consistent results. I may have those reversed.
Anyone find any other shortcuts?
Jagzzz
Aug 8, 2021 02:45 PM
DFW
Jul 27, 2020 02:44 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
Wayne Enticott
Sep 29, 2015 08:55 AM
