2012 XFR - Passenger Window Rattle
Old Sep 6, 2020 | 05:53 PM
Jaaaggg's Avatar
Default 2012 XFR - Passenger Window Rattle
I took apart the passenger door and wrapped all of the cables inside that cause rattles, but recently the passenger window has been rattling on bad roads. When I have the passenger put pressure on the glass, the rattles are gone. Has anyone else had this issue and know a way to fix it?
Old Sep 7, 2020 | 03:52 PM
Bigv's Avatar
You’ll need to take it apart and find which part is rattling
Don’t say window!
Old Sep 7, 2020 | 05:47 PM
Jaaaggg's Avatar
Don’t say window!
Took it apart already and could not figure out the source. The rattle is coming from the glass, but cannot figure out what's causing it.
Old Sep 7, 2020 | 06:08 PM
Bigv's Avatar
You’ll need to take it apart again and kinda really gently hit it until you pinpoint the rattle
Not with a hammer! More the heel of your hand
If you break it, you’ll never find me!
Old Sep 8, 2020 | 11:21 AM
Jaaaggg's Avatar
Already did exactly that, the rattle is around where the upper door frame meets the glass, not sure where to go from there. All of the speaker grills and wiring inside the door has been padded. I wanted to see if anyone else had this issue.
Old Sep 8, 2020 | 01:53 PM
Bigv's Avatar
You mean right at the top when the window finally shuts?
Old Sep 8, 2020 | 02:46 PM
Jaaaggg's Avatar
I am talking about this area. I removed all of the panels and hit the metal part of the door, I can hear the glass rattle.
Old Sep 9, 2020 | 02:29 AM
prolepsis's Avatar
When does it rattle? For example, only when the window is fully closed, or only when partly open, only when fully open, or all of the above?
Old Sep 9, 2020 | 10:29 AM
Jaaaggg's Avatar
I tested fully closed and partly open, rattles in both scenarios. I need to check fully open.
Old Sep 9, 2020 | 02:55 PM
Bigv's Avatar
Take the door card and speaker panel off. Stick your hand up the hole. Start banging while holding the glass at different positions. When the rattle stops, you’ve found the problem area.
It’ll be something daft - guaranteed!
Old Sep 11, 2020 | 09:13 AM
prolepsis's Avatar
I wonder if the rear channel has become loose somehow. From memory, there are 2 screws that secure it to the inner door; one high and one low. This channel needs to be loosened to remove the window glass. If you’ve replaced a lock mechanism, then it may have become loose.
Old Sep 19, 2020 | 12:17 AM
hiltoncam's Avatar
Try this
alanroberts50
Aug 16, 2020 12:17 PM
SamtheSham
Jan 29, 2020 09:53 AM
Richardscot
XF (X260)
Mar 23, 2018 02:58 AM
Brazz
Apr 4, 2013 01:39 PM
damianpenney
Feb 15, 2010 12:27 AM
