2014 AWD Front Hub and Bearing Assembly Hard to Find
Old Oct 10, 2024 | 10:32 AM
kkurulak's Avatar
Default 2014 AWD Front Hub and Bearing Assembly Hard to Find
Has anyone found a place to purchase front hub/bearing assemblies for the X250 AWD model? I had the dealer looking for two weeks for my 2014 XF AWD without any luck, other than a full assembly including a new knuckle at a very steep price each.
There are many listings for AWD only to find that they are actually RWD versions. I can also find 2015- hub assemblies but it looks like the x250 models have all but disappeared.
Any input would be grateful and although I would like to have shipping to Canada, I could also use one of the routing companies if only sold in the US.
Kevin
Well, I just received confirmation that there is no OEM version of the Hub and Bearing assembly and they are only shipped as a vertical link assembly. Driver left is Knuckle with the bearing/hub assembly and the part number is C2Z29557 while the front right Knuckle with bearing/Hub is C2Z29556. Sent out requests to the usual locations for quotes.
Old Oct 10, 2024 | 02:36 PM
Six Rotors's Avatar
Rock Auto appear to have after market front wheel bearings, although some are for RWD cars only. They ship to Canada.
Old Oct 10, 2024 | 03:31 PM
kkurulak's Avatar
Thanks, Six Rotors, unfortunately they only have front hubs for RWD cars, none have the splines for the CV Axles. I have been trying to track some aftermarket, but I can't see any. Only option so far is finding the bearings or option two, to bite the bullet and purchase the link-vertical assembly for a complete swap out.
Old Oct 11, 2024 | 10:54 AM
pab's Avatar
pab
SNG Barratt?
https://www.sngbarratt.com/English/#...Parts/Families
You dreamed of a big star -
He played a mean guitar -
He loved to drive his Jaguar...
So welcome to the machine
Old Oct 11, 2024 | 11:15 AM
kkurulak's Avatar
Thank you pab, actually talking with SNG Barratt and British Parts, I also found here in Canada at OEM Pro Parts (According to their web site) that they have through an Ontario dealer but I have not received any replies to date so they might not have here in Canada.
I have found some other locations but when the final price per part is calculated, I am seeing an average of $1,100.00 - $2,700.00 CAN per piece depending on who is selling.
Both SNG Barratt and British Parts have been very quick to respond
Old Dec 6, 2024 | 11:51 PM
kkurulak's Avatar
Well, got my hands on some new knuckle assemblies and installed the passenger side. Had a few nail-biting moments, first finding out that the upper control arm ball joint was played with before as the Allen socket in the stud was a wee bit stripped, lucky I had a reverse extractor. The second crazy situation was the half-shaft acting like the splines were welded to the hub, it took a few hours and a lot of pressure to pop loose. I am now playing with the old knuckle to see how feasible rebuilding will be. Once I get around to doing the driver's side, I'll make a tutorial as I didn't see much out there for guidance on the AWD versions.
Also, pulling the hub would be a must if you ever snapped a lug bolt on one of these AWD front ends.
Popping out the hub is easy, using the bearing kit, I was able to make quick work of it, keeping in mind the bearing splits, pushing the bearing sleeve out after requires a press.
Old Mar 25, 2025 | 03:03 PM
JoshMcMadMac's Avatar
I'm tackling the same job on my X351 XJ. Do you happen to know the torque requirement for the axle nut and ball points?
Old Mar 25, 2025 | 04:19 PM
kkurulak's Avatar
I’m away and will not be back home until Thursday, I’ll confirm the shop manual and post it.
Old Mar 26, 2025 | 08:43 AM
I really appreciate it. I tried searching a few different ways and finally found it:
https://www.jaguarforums.com/forum/x...6/#post1826887
stone4140
Apr 15, 2024 07:42 AM
Austin Laugen
Jun 28, 2022 11:38 PM
Bc xj
Jul 9, 2019 07:07 AM
03Xtype
Oct 19, 2015 06:25 PM
Gergs
Oct 29, 2010 03:38 PM
